Question about Brother MFC 420CN All-In-One InkJet Printer
Cannot replace back panel of my brother mfc-420cn printer
Cannot replace back panel of brother printer after removing a paper jam
  • 286 Answers
Hold the rear cover so that the top is horizontal and the rear is vertical. Line it up with the hole in the back and push straight in.
Posted on Jan 22, 2009
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Paper jam - took back off but can't see any paper
Open the top cover.. check if there is any residual paper .. if you can't find it behind.. most probably the paper is at the print head area..
if still can't find the paper, worst case is that your paper path sensor is broken..
May 23, 2010 | Brother MFC 420CN All-In-One InkJet...
Paper jamed
Apr 09, 2010 | Brother MFC 420CN All-In-One InkJet...
Paper jam, machine says paper jam, but no paper is jammed
pls define where it shows the paper jam indication as back door or output bin.......
Mar 21, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
May 14, 2009 | Brother MFC 420CN All-In-One InkJet...
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Paper jam - cannot get the paper tray to open
open back side paperjam clear cover. simply push the paperfeedroller towards the inside and pull the paper tray carefully out at the same moment ;-)
Feb 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
35 people viewed this question
James Cagle
James Cagle
Jim Keysor
