Question about Impact 1/2" Cordless Wrench Nikota Automotive Sealed
Nikota high power flash light
I have a thin in diameter stainless steel flashlight made by Nikota. I cannot get it open to replace the batteries. Where in the world do you ull this apart or unscrew it to replace batteries?
  • 100 Answers
Battrey is in the bottom, usually sqeeze it and the battery drops off
Posted on Feb 16, 2009
Tip
Air To Water Heat Pipe Heat Exchanger
General Information
Air to water heat pipe heat exchanger is mainly to heat water using the hot air from heat recovery, it can be used for domestic water, water for boilers or production process. The exchanger is constructed using a partition in the middle to separate the exchanger, both sides are independently sealed. A single heat pipe can be replaced. While working the hot air flows from one side to the other side, the heat pipe absorbs heat. Meanwhile, cold water flows from the reverse side, the heat pipe releases heat, thus heating the cold water from the reverse side. The outlet temperature is not lower than dew temperature.
Field of Application
-feed drying
-cereals and oil processing
-chemical industry
Specification
Advantage:
-high heat recovery efficiency
-seldom temperature difference, fast heat starting, good isothermal
-the speciality of the heat pipe results in a high wall temperature, exhaust gas temperature can be reduced without reaching the acid dew point, avoid the corrosion of the equipment.
Core tube material: stainless steel, carbon steel
Fin material: aluminum, stainless steel
Tube/fin bond: extruded, high-frequency welding
Tube arrangement: staggered
Core tube external diameter: ?25
Core tube wall thickness: 2-3mm
Fin thickness: 0.4mm
Fin height: 12.5mm
Fin spacing: 3mm
Temperature range: 20~150?
Order Information
P/N Description: HP-XYZ-N
Note: X should be replaced into S, C
Y should be replaced into S, A
Z should be replaced into ET, W
N means the power needed
S-stainless steel
C-carbon steel
A-aluminum
ET- extruded
W- high frequency welding Air To Water Heat Pipe Heat Exchanger
on Dec 14, 2016 | Miscellaneous
I replaced the batteries and followed the instruction.
You need to initialise the weighing process by tapping your foot on to the scale to start it...but wait for it to zero...then step on it.
Jul 02, 2015 | Taylor 7404 Ultra Thin Lithium Scale with...
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Impact 1/2" Cordless  Wrench Nikota Automotive Sealed Logo
235 people viewed this question
Top Impact Tools & Hardware - Others Experts
Matt Olenzek
Matt Olenzek
john h
Are you an Impact Tool and Hardware - Other Expert? Answer questions, earn points and help others
