Question about U-Line Refrigerators
I have a U-Line 2175WCS-01 with a loose handle, how do I tighten the handle?
  • 30 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
Posted on Dec 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 13, 2010
SOURCE: loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Posted on Jan 19, 2010
Tighter door handle on freezer door maytag mf12568aeb?
Slide the handle up tightened the screws underneath and line up and slide the handle back on
Jan 03, 2016 | Maytag Refrigerators
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Loose single handle no brand name faucet
There is a little rubber icon Red for Hot and Blue for the cold on the front of the handle. Remove the rubber insert from the handle. There is a small allen screw that needs tighten to tighten your handle.
Mar 05, 2013 | American Standard Plumbing
The handle on my refrigerator door (Admiral side by side model LSD2615HEZ) is loose. How do you tighten the handle?
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Dec 30, 2009 | Refrigerators
Handle on door loose how can i tighten it
Pop out the little plastic buttons. The screws are under them.
Aug 06, 2009 | U-Line Icemaker
Loose handle on door
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
