Question about Casio JF-100TE Calculator
Casio JF-100TE Battery Replacement
The case has two screws in the back at the top. Even with both screws removed the case halves (front and back) will not seperate. There are a couple of slide switches on the front. Other than that there are no other fasteners visible. The battery type (LR44) is molded into the back case. The Casio manual says something about taking it to a Casio service center to have the battery replaced. Yea right. That's bunk.
Remove two screws at top. Then there are 3 hidden **** on both the right and left side of unit for a total of 6. Pry the case apart starting at top on one side. Then slide a small thin screw drive down the side till you come to first *** and pry just a little till it comes apart. The first *** is on the side at display height center. The next *** is between the GT key and division key on side. The next *** is on side at top of plus key. The case will now swing open like a door with the same 3 **** on on side of case. The top of case **** are female. The bottom of case **** are male. The battery slides in and out. Make sure you get + and - right.
My problem is I changed the battery but display still only works with solar power.
Posted on Mar 06, 2009
    Habit-Forming:
    New Friend:
  • 3 Answers
Taking the back off The Casio JF-100 calculator is similar to the ...TE. Remove the two screws at the top back. Place a small screwdriver blade along the seam where the back plate fits into the front plate. There are 3 fasteners on each long side and 1 fastener on each of the front and back sides. Find the spot where it's the easiest to separate the back plate from the top plate (there are only two). Carefully twist the blade to cause an opening. Then proceed sequentially around the perimeter releasing each fastener. The front plate will easily separate from the back plate at this time. There are no parts that will fall-out--don't worry. Replace the battery. Press the front and back plates together to snap the fasteners.
Posted on Nov 23, 2013
How do I change the battery in a casio tk 2700 cash register
Remove upper casework:
WARNING! - RISK OF ELECTRIC SHOCK.
Ensure power to the ECR is off and the power cord is disconnected before connecting the interface.
a. Locate the power switch and switch off the ECR. Also disconnect the ECR from the mains supply.
b. Unlock and remove the printer cover (by tilting it up from the front).
c. Remove keys from mode locks etc.
d. Remove the grey name-plate located half way down and to the left of the register.
e. Remove the single screw located behind the panel (bottom right of printer mechanism).
f. Push in the two tabs located either side of the register and slide the top cover forwards. The cover should now lift upwards, away from the register.
g. Move the top cover on to its side towards the right of the register (take care as there are still cables linking the top and bottom halves).
ftp://files155.cyberlynk.net/uploads/SIDG/Casio/catk2700.pdf
May 28, 2015 | Retail Supplies
How do we replace battery for a JF-100MS calculator?
I couldn't find the manual for your JF-100MS but I have a Casio FX series calculator that, like yours, is solar + battery backup. On the back of the calculator there should be a small door or coverplate with a tiny screw. If you remove the screw the cover should come off and you can then access the button cell battery for replacement.
Jul 29, 2014 | Casio JF-100MS Desktop Calculator with...
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
Braun shaver 5314. The green light works when plugged in. Does not hold charge to work at all. What is the problem, can it be fixed or should I begin looking for a new shaver?
Battery is dead. You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Remove foil and cutter. To open the shaver, pry off the two screw covers on the bottom and then remove screws. Remove the swivel fram on top by removing the two tiny screws. You can then gently pry the two halves apart from the bottom. You will be able to access the battery pack once the case is seperated
Dec 28, 2010 | Braun Health & Beauty
How do i set the euro conversion rate on my casio jf-120ter caclulcator
Already answered here: http://www.fixya.com/support/t292440-casio_jf_120er_euro_rate_set
Mar 23, 2010 | Casio JF-100TE Calculator
Whats the procedure for changeing air filters in a yamaha royal star tour deluxe 2005
This procedure must be performed on both sides - you'll find the air filter cases mounted high, immediately behind the cowlings. Yamaha specifies removing the cowlings, but I just remove the top screw in the front of the cowling and bend it forward slightly to get to screws and bolts.
The air cleaner cases are mounted by hex-head screws top and bottom; loosen them, then look for a large rubber hose from the case to a duct beside the case. The case is held by a flexible clamp with a phillips-head screw adjustment - loosen the screw and the case can be removed.
Turn the case so that the rubber hose is facing up; there are five screws holding the case halves together. Remove them to split the case. The filter is secured to the side of the case that the rubber hose joins, loosen the two screws in the front (forward-facing) of the filter and remove.
Secure new filter with the screws that held the old one, rejoin the case halves, put the case behind the cowling, secure the rubber hose to the duct, screw top and bottom bolts through the case to their mounts, tighten cowling mounts.
Repeat on the other side and you're done!
Mar 04, 2010 | 2005 Yamaha Royal Star Tour Deluxe
How do you turn off this calculator.
It is solar powred and will turn off by itself. Don't worry it doesn't cost anything.
Sep 06, 2008 | Casio JF-100TE Calculator
CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Jan 15, 2008 | Casio JF-100TE Calculator
Calculating percentages
Type 100 x 20%, and then hit the minus button
Dec 05, 2007 | Casio Office Equipment & Supplies
I'm so stupid
  1. Remove the top gray lid of the calculator
  2. Insert paper through the back side slot near the power charger
  3. Turn the calculator on print
  4. Press FEED a couple times
Feb 26, 2007 | Casio HR-100TEPlus Calculator
Casio JF-100TE Calculator Logo
646 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
