Question about Tessco BLISS BTH-098 Bluetooth Headset
How to play musuc on headset bth-098 - Tessco BLISS BTH-098 Bluetooth Headset
PASSCODE FOR BLUETOOTH HEADSET BTH-318
NOKIA 1100 has no bluetooth sorry pal
Sep 21, 2011 | Nokia 1100
BTH-068 headset instructions
my bth-068 won,t regaster, but I have been using it for about seven month's on my PS3
Sep 04, 2010 | Computers & Internet
Lost manual for BTH-03B1 where can i get a copy as need the factory setting pass code to use it again as will not register again
The headset has two buttons, one big (MFB) which does multifunctions inc volume + and one small which does volume -
To pair start with headset OFF and have your handset within 1 metre.
Press and hold the MFB for 8 seconds until the headset LED flashes red and blue. Its now ready for pairing.
Activate your mobile Bluetooth function to find and select BTH-03B1 from the list.
Enter the passkey "0000" when asked
When pairing is completed the LED will flash blue every 3 secs in standby mode.
To operate in use use the MFB to increase volume. You also use this to answer calls by press for 1 sec. or end call by pressing for 3 secs.
You can do headset to handset/headset and use the small button by pressing 3 secs to transfer.
Feb 06, 2010 | Radio Communications
Acer Extensa 5630EZ no Bluetooth device
Ansolutely! The slider is there on most of the models but when they are ordered it will depend on whether that addition was paid for before the module is added. If the advertisment you saw stated bluetooth and you think you should have bluetooth as pewr the advertisment I would be claiming misleading advertising. State that you wre lead to believ it had blootooth intsalled as it was ointed out at the time of sale.. Ne firm, they love to wiggle out of responisble sales and advertising. Maybe you misread the name? wasn't it SCAM?
Jul 29, 2009 | Computers & Internet
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Tessco BLISS BTH-098 Bluetooth Headset Logo
Top Tessco Radio Communications Experts
eradiostore
eradiostore
Are you a Tessco Radio Communication Expert? Answer questions, earn points and help others
