Question about Cuisinart Refrigerators
Don;t know how it works
I got a cusinart private reserve wine cellar wbc 1200, but I don'thave the manual, if any way that i can get it. Thanks
  • 8,596 Answers
The manual is available from:
http://www.cuisinart.com/share/man/633_man.pdf
-Tha Mp3 Doctor
Posted on Feb 15, 2009
How do i set the temperature on my haier model number hvdw20abb
Thanks for including the make and model number.
Without these, an answer is impossible.
Here is a link to the manual, which describes in detail how to adjust the temperature.
Haier HVF020A User Manual Wine Cooler Features And Use Initial Set Up...
If you found my answer helpful, please rate. Otherwise, feel free to ask for any further info if needed.
Oct 30, 2014 | Haier HVDW20ABB 20 Bottle Display Window...
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Punched inside panel.
sounds like some one tried to defrost it with an knife. you can order the evaporator thru haier but unless you know how to do sealed system work you will need a qualifed refrigeration company to repair it for you if you provide the part approximate cost in the states is around 300-400 dollars. good luck peyton
Jan 29, 2009 | Haier HVH025A Wine Cooler
Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I also had one of these CWC 900 units that quit working. The interior temp was 77deg F and the outside was 70 deg F.
The exterior panel was very warm to the touch where the heat exchanger was.
Like a previous person stated, there are two fans. One on the control unit board and then the main cooling fan for the exchanger. In my case, this main cooling fan had quit working - allowing excess heat to build up.
Solution: Unplug the unit! Remove the side panel of the CWC 900. First remove the 8 "finishing" plastic plugs that hide the screws. This was done with a sharp point on an ice pick to pry them out. Then remove the 8 screws with a torx T10 driver. At this point, plug the unit in and lower the temperature setting. In my case the small fan kicked on and the larger one did not. Un plug the unit. If you try and manually turn the fa you will feel resistance. Remove the cooling fan and black housing w/ 4 phillips screws. seperate the wires from the cable ties and then unplug the fan - you may have to remove a small amount of a plastic type glue to unplug the fan. Remove the fan from the plastic housing w/ 2 phillips screws. This is a fan made in China and I was unable to find a replacement on the web. Remove the center sticker on the back with the fan model number. Remove the center black plastic plug with a sharp point. You will now see the end of the shaft and a small split keeper ring. This ring is made of plastic - be gentle. Pry it open and remove it from the shaft (KEEP IT). Once the keeper is removed, you will be able to pull and seperate the motor from the fan blade and expose the shaft. I was not able to remove the small bearing from the motor so I wipe the shaft clean, applied white lithium grease and the re-assembled the unit. Fan spun freely. Put everything back together and the unit should be fixed!
Hoped this helped.
Mar 19, 2008 | Refrigerators
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Refrigerators Logo
414 people viewed this question
Top Cuisinart Refrigerators Experts
gbob59
Richard Sanderlin
Level 1 Expert
Tom Chichester
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
