Question about Malwarebytes En Life Online for Windows, Unix\Linux
Is there malwarebytes for unix - Malwarebytes En Life Online for Windows, Unix\Linux
What is unix and how do I use it?
Unix is a multi user multi tasking operating system. Mainly using for scientific process and database storage with well security. You can install ubuntu 12.04 LTS to learn Unix in GUI environment.
Sep 27, 2014 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Tip
Manually Removing Any Trojan Horse Virus.trojan Zlob Virus Horse Removal
<br />Description<br /><br />The Trojan horse virus is a computer virus that attaches itself to certain files and programs downloaded from the Internet. Once it finds its way onto a computer, it Downloads Fake Rogue Antivirus Application attaches to other files and multiples. This makes the computer slow down, and some users may even find that they can't Open exe Files or perform certain actions. The only way to fix this is to manually remove the Trojan horse virus by removing all of the infected files and programs from the computer.<br /><br />Malwarebytes' Anti-Malware Free Download<br /><a href="http://www.malwarebytes.org/">http://www.malwarebytes.org/</a><br /><br />Free Remote Desktop Help <br />Because the Trojan horse virus can be hard to remove please add me to one of the following resources for free remote desktop help <br /><utube src="1ZV1UK5s608">
on Jan 16, 2011 | Malwarebytes En Life Online for Windows,...
Tip
Conficker
Malware type: Worm
Aliases:
Symantec: W32.Downadup.C
F-Secure: Worm:W32/Downadup.DY
CA: Win32/Conficker.C
Sophos: Mal/Conficker-B
Protection:
First of all Conficker Worm only impacts Windows Operating System so Mac’s(Macintosh) and Unix/Linux users are safe!
Step 1: Open Internet Explorer Go to Tools>Windows Update make sure you are up to date with patches.
Step 2: Scan your PC Online with Microsoft Live Scanner
Step 3: Download Conficker Removal Tool from Symantec's Website , Trend Micro’s Cleanup Engine, or Malwarebytes
Step 4: Download AVG Antivirus FREE software from http://www.avg.com/free & make sure to update your virus definition.
Well after these 4 steps above, you should be safe.
more info about Conficker and other malwares
on Apr 01, 2009 | Internet Grisoft AVG Security Full...
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
Help, I can't install Adobe Reader as it says another program is being installed and I need to wait until it is terminated --- I have the same problem with Itunes Update. I am using Windows Vista. Thanks,...
Try running Malwarebytes free version from a usb drive if possible. Once you download it onto the drive rename it from MBAM.exe to winlogon.exe (a virus may be the prolem and no virus will look twice at winlogon as it is a system process), then boot to safe mode and send malwarebytes to desktop (create shortcut), intall update and run full scan).Follow instructions for getting rid of malware.
If that doesn't work, try bringing up task manger (you can try this first but just reboot into safe mode before installing malwarebytes)and click processes tab look for and end any Adobe processes
and also any updating processes (they will comeback after reboot). then try downloading your Adobe reader. Good luck.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
How to install unix sco kindly give full details
start the computer with the Unix disk in the drive.
Choose the option to run unix without installing to the pc.....(this runs without a HDD>Itll take some time but let it install all the way, and as system is fully running..Choose "install unix " from the drop down menu.
After installation, eject the cd and set up to boot from the HDD.
Jan 27, 2010 | Apple OSX 10.3 for Unix, Mac
UNIX suitable for biginers
I would like to humbly state, if you are completely new to Unix it may be in your advantage to start with a flavor of Linux.
Poseidon Linux is specifically geared towards the scientific community, and contains many applications and tools centered around those needs.
Here's a download link for Poseidon in English:
http://poseidon.linuxfreedom.com/
Scientific Linux, which is geared towards your ambitions is based of the Red Hat Distribution, which allows for easy installation via "Red Hat Package Management" or RPM.
Here's a link to Scientific Linux:
https://www.scientificlinux.org/
Should you feel that a true Unix experience is required, the choice of Unix would be up to you. The reason why you would have to choose a Distribution on your own is because mostly all Flavors of Unix do not come with mission-specific applications installed.
You can get Unix in both Open (Free) or Licensed.
Try this link for different flavors:
http://www.crucialp.com/resources/tutorials/dedicated-server/unix-flavors-flavours-distributions.php
Hope this information has been helpful.
Apr 24, 2009 | Computers & Internet
What are the differences between windows vista and unix
Hmmm... This is a BIG question, and it has a HUGE answer.
Have you ever seen Unix and Vista? I think you would immediately see the difference between the two.
1. Vista has a Graphic User interface, Unix is a command line interface.
2. Totally different systems (Filesystem, application, Kernel... whatever)
3. Age - Unix is ooold, and Vista is new (Unix dates back from the 1980's)
Well i can go on like this for days ...Google it more.
Darko, Serbia
Mar 19, 2009 | Microsoft Computers & Internet
I am in new in unix operating system please suggest me
Try these links
http://www.debianhelp.co.uk/commands.htm
http://www.linuxlots.com/~jam/guide4.html
http://tldp.org/LDP/Linux-Filesystem-Hierarchy/html/
You will be familier with linux once you understand the files system...
Mar 01, 2009 | Sun Computers & Internet
What is the difference between unix and linux
UNIX is a operating system which has only command user interface, and if the unix is installed in the system you cant install any other operating system after that ... one separate system must be allocated for the unix ...
LINUX is the graphical user interface and it supports multiple operating system ..
UNIX and LINUX are almost same, almost all commands which supports in UNIX supports in LINUX too .. with some extended features just like GUI(GRAPHICAL USER INTERFACE),SECURITY,MULTI USER,MULTI TASKING,etc
COMMAND USER INTERFACE - the input is made to the computer by using commands and the output is obtained by command or by printer ...
GRAPHICAL USER INTERFACE- the input is provided to the computer through the other input devices like mouse,joystick etc
the input is provided either by command or by the just clicking the mouse on the particular icon ...
example for graphical user interface is windows,Macintosh etc ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
Malwarebytes En Life Online for Windows, Unix\Linux Logo
23 people viewed this question
Top Malwarebytes Video Game Consoles & Games Experts
James Wishart
Are you a Malwarebytes Video Game Console and Game Expert? Answer questions, earn points and help others
