Question about Panasonic Kv-S5055c-V Flatbed Scanner KVS5055CV
Panasonic kv-s5055c error message
Error message says "paper remains in the scanner", but there is no paper in the scanner
ctf1800
  • 4402 Answers
SOURCE: Panasonic Hi-speed scanner
if your positive there is no paper and you have unplugged, you can take canned air and spay it out otherwise you have a bad sensor
Posted on Dec 12, 2007
SOURCE: Remove paper from scanner
I have this same problem every time I unplug my Panasonic KV-2026C. I've lost the original disk with the utilities, and the Panasonic web site says, they only provide the disk with the original equipment. You know, I'll never buy another Panasonic product. But I'm usually able to get the ready light to come back on by doing the following. I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble). Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate. I also connect the scanner to the laptop and get the "blip" sound from Windows to recognize the scanner. I don't know if that's important or not. Then I say a healthy prayer, plug it back in and shut the back door. If there is a god on duty that day, the ready light comes on, and stays on as long as I have the power connected. I just went through the process and it worked!!!! The minute the power is off, the error light stays on. Good luck, my friends! Joe Diehl, Seattle WA
Posted on Aug 10, 2008
prawinmv22
  • 106 Answers
SOURCE: the ready/error indicator is red... the error
hi....
I have this same problem every time.....first unplug it.....I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble).
Posted on Jul 04, 2009
  • 16 Answers
SOURCE: Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
SOURCE: Our panasonic scanner has a
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Posted on Nov 22, 2010
I am not sure if you have the manual for it so here it is just in case.
http://service.us.panasonic.com/OPERMANPDF/KVS2026C.PDF
Since there are many steps to opening it to clean, the problem may be reassembling it. You can also unplug it and leave it off for 30 minutes to reset its internal memory. You can also press Start and hold it for 5 sec and do the same with the menu button. If after trying this, your machine does not reset, let me know.
Nov 18, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Kv-s2026c paper jam
Are you just receiving paper jam message or paper is actually jammed in the unit.Or the paper is getting jammed every-time while getting the printout.Click this link below :-----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Panasonic KV-S2026C Pass-Through Scanner
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
Unreadable message error
That is a driver problem. You need to install the correct drivers for your operating system. Visit the Panasonic download page for the correct drivers.
Regards,
MyEfact
Jun 30, 2010 | Panasonic KV-S3065CL Path-Through Scanner
Jul 30, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Nov 01, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Panasonic Kv-S5055c-V Flatbed Scanner KVS5055CV Logo
510 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
