Question about Code-Alarm Code Alarm Transponder
I have a 96 s-10 that has a code alarm 1000 SE.
When I changed the battery, the flashers would go on and off. I can't get the vehicle to turn over. It starts intermitently. Most of the time it will not. The alarm system was on the vehicle when we got it and we don't have a manuel to refer to. I'd like to be able to reset the unit so we can start the vehicle and even take the system out.
Thank you
  • 112 Answers
Look for purple wire in the ignition harness, it will be cut going to a relay and then back to the opposite side of the purple wire, cut this out and connect purple to purple... it will start every time now (provideing this was the propblem)
Posted on Jan 24, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
The car soulds like the battery is low but when it starts the flashers come on.
Often an alarm system will register a low battery voltage and presume the vehicle's battery is being removed to prevent the alarm from going off. They will then begin flashing and or sounding the horn.
In your case, I would presume that the battery voltage is too low which may indicate either a failed battery, or a parasitic voltage drain.
First, get the vehicle started, and run the vehicle for a good twenty or so minutes to get some charge to the battery. If you don't want to waste fuel however doing this, then I suggest using any battery charger, as all we want to do is get some voltage back in the battery. If you are using a charger though, then charge on a lower voltage setting overnight.
Once you have the battery charged, run off any surface charge by turning the vehicle lights on for a minute, then turn them off again.
You need an ammeter for this next part:
Disconnect the battery positive terminal and connect the ammeter in series with the battery and positive lead.
DO NOT ATTEMPT TO START THE VEHICLE!
With all vehicle systems off, the key out, doors closed and alarm 'OFF', bonnet close switch depressed, or bonnet/hood clasp closed (need a screwdriver), take a reading from the ammeter.
After probably no more than twenty minutes, the ammeter should be reading 0.03 amps and not much more. Anything like 0.5 or 1 amp means you have a battery drain.
If this is the case, then start by disconnecting the alarm system. If the alarm system has it's own separate speaker/horn, then disconnect this first. Many of these horns have backup batteries, which only last three or four years before they fail, which causes them to constantly draw from the vehicle battery and then flatten it when parked.
Every time you disconnect an item or system, check that ammeter again to see if the amps have returned to normal. Pull fuses one by one, checking the ammeter each time for any change until you find the system which is causing a drain, then attend to that system.
If your amps are normal however and your battery is still loosing charge when parked for any short length of time, i.e. a few days or so, then your battery is at fault and requires replacement.
Just before changing your battery, do one last check, which is with the vehicle running. You need to reconnect any battery cables, and start the vehicle. Using the voltmeter once more, check the voltage across the terminals with the engine running. This is your charging voltage and it should go up to around 14 volts if revving the engine slightly. If still around 12 volts only, then you have a charging issue, which is probably the alternator.
Nov 11, 2012 | 2008 Toyota Corolla
I bought a new battery and still wont start
Have you had the alternator checked? may not be charging the battery.
Oct 30, 2012 | 2004 Mercury Mountaineer
2007 z1000 turn signals not working from switch but do flash with alarm
Hi, have you checked the fuse for the direction indicators, the alarm is a separate supply, other things may include a faulty switch or a flasher relay
Feb 21, 2011 | 2007 kawasaki Z 1000
The battery ran down on my wife's 2002 Honda Accord SE. I put a trickle charge on it over nite and battery is charged but the stereo doesn't work nor the alarm system (blue lite is not on). How do I...
Check for a sticker with the radio code inside the glove box. Some dealers fixed a second sticker in the owners manual. If not available, get the code from a Honda dealer, and be prepared to show VIN number, and proof of vehicle ownership.
Mar 29, 2010 | 2002 Honda Accord
I changed the battery on my 2001 Tiboron and now the factory alarm system will not let me start the car. I do not have a key fob
In order to 'RESET' burgular alarm, you MUST have the remote keless entry fob programmed for the vehicle - no other way unless you want to bypass/disable the burgular alarm relay and alarm horn. This, however, does not disable the 'flashers' when the alarm is activated. Bypassing the relay will allow you to start the engine, but you'll be driving around with your parking lights flashing.
Sep 06, 2009 | Hyundai Tiburon Cars & Trucks
Car: 3 series BMW - Problem I can't reset the alarm
BMW 3 series 2007. Have changed tires, but cannot reset air pressure alarm ?!
Mar 26, 2009 | Anti-theft Alarm System 3 Series E90 E92...
Car alarm wont turn off
Try changing the batterys in the remotes mate
Feb 16, 2009 | OEM Systems Vehicle Parts & Accessories
Check Engine Light on and hazard lights don?t blink
locate the relay for the alarm and or the flasher unit and replace it...
Robert
Nov 25, 2008 | 1999 Audi A4
Code-Alarm Code Alarm  Transponder Logo
170 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
