Question about Orbit 2-Dial Hose Faucet Control Timer #62015
I have a Watermaster 57794 with 4 stations , can find the user's manual, where ican i find it here on the net ?
Kenwood food processor fp226
First of all, thank you very much Marian for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food_Processors/57794%20Iss%205%20B5%20FP220%20English%20only.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 15, 2011 | Food Processors
Ican't download a copy of the sansa fuse+ users
You can download the manual from the manufacturer's web site at
http://www.sandisk.com/media/911811/Sansa%20Fuze+%20UM_112210.pdf
Sep 10, 2011 | SanDisk Sansa Fuse MP3 Player
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have a watermaster timer and the fuse keeps blowing. It's kept indoor so it's not getting wet. What would you recommend checking?
Watermaster timer has 24V AC transformer that plugs into outlet.
I don't know if the transformer is causing problem, or is circuit has a problem.
1) Use cheap circuit analyzer from home center to check outlet for problems.
2) If possible, replace Watermaster transformer with 24V AC transformer available from home center doorbell section.
3) Move transformer to another outlet and see if problem persists.
4) Actions above can give some indication if transformer or circuit are causing problem. If circuit is suspect, move wire to another circuit breaker, and/or replace circuit breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Apr 14, 2011 | Hardware & Accessories
Looking for manual Orbit Watermaster 57012 Controller.
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57004-57006-57008-57012-before-2002-Sprinkler-Controller-Owners-Manual.pdf
Jan 10, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
I have a watermaster 4 station timer and lost the instructions, can you help>
http://www.acehardwareoutlet.com/(5y1u4o55lkcvp0e2i3vjxb2g)/ProductDetails.aspx?SKU=7095045
this should give you the instructions you need
Apr 10, 2009 | Hardware & Accessories
Orbit 2-Dial Hose Faucet Control Timer #62015 Logo
108 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
