Question about Cyberhome CH-DVD 300 DVD Player
Setup menu Our Cyberhome DVD 300 shows us the setup menu. When we press the SETUP button, however, it does not return to the usual home screen so that we can playback a DVD. instead we get another screen with folders on it (e.g. CONFIG, DVD ROM, fscommand). Pressing SETUP only gets us back to the SETUP menu.
  • 153 Answers
T goes to the options in dvd first then to the player settings
Posted on Jan 22, 2009
  • nicra7 Jan 22, 2009
    its the basic function nothing to be worried of better clean the parts inside
I just purchased a new surround sound systemm and everything says I need a disc to get started but there wasn't any disc in the box ?
hi,
there is no need fo any disc. u can make the setups manually. make all the connections try the following.
Press [DVD] to select "DVD/CD".
Press [START] to show the START menu.
Press [up, down button ] to select "Setup" and press [OK].
Press [,up, down button ] to select menu and press [OK]
Press [up, down button ] to make the settings and press [OK]
Press [up, down button] to select the item and press [OK]
To return to the previous screen, press [RETURN].
To exit the screen, press [START]
The settings remain intact even if you switch the unit to standby.
ok
Dec 18, 2010 | Panasonic SCPT480 Theater System
Wuz n menu settings, hit wrong button, now only hve rolling pix!
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and ntsc.press it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
May 18, 2009 | Cyberhome CH-DVD 300 DVD Player
Don't shoe the wallpaper Cyber home en modelo DVD-300
when the a dvd is stop or not inserted press the setup button (depending on firmware version) you will see system menu the screen saver should be on the first menu press the enter button to access different menus and sub menus
as for region i cant help you through traditional methods
Apr 26, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
It does not want to load anything.
have you tried resetting it to factory defaults?
Jan 10, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Aug 04, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
