Question about Lands Phones
Uniden D1484 does it have speed dial? - Lands Phones
2 Suggested Answers
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
How do I un-block a phone #? Uniden 6.0 # D1484
Your phone doesn't have the call blocking feature. Please check with your phone provider.
Jun 27, 2015 | Uniden Lands Phones
How do I set the time and day on my Uniden hands free phone?
Press MENU/SELECT to bring up the menu. Use up/down to select "Date & Time" and press MENU/SELECT.
If you have caller ID, the first time a call comes in with the caller ID info, the phone will automatically set the date and time.
If you need a manual, you may download a copy here.
Jul 23, 2012 | Uniden Cordless Phone
Speed Dial
Select the model of the phone from the list at
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 20, 2010 | Uniden Cordless Phone
I programmed a speed dial number, how to I dial
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Oct 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
NOTE:
warning.
Chain Dialing
number.
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Sep 22, 2008 | Uniden 5.8GHz Dual Cordless Phone
Speed dial on uniden
When the phone is not in use, press and hold the number key (0-9) that is assigned to the phonebook entry. Press flash on the handset to dial the number.
Apr 23, 2008 | Uniden DCT756-3 Phone
Speed Dial for a Uniden Model DCT648-3
Do you have a copy of your owners manual? If not, here is a link to a pdf format version of it, from the Uniden website:
http://www.uniden.com/pdf/DCT648-3om.pdf
Speed Dialing
If you store a phone number in a speed dial memory location (10 locations: SPD1 - SPD0),
you can use the speed dialing feature. When the phone is in standby mode, press and hold a
number key (0-9) associated with the speed dial until the phone number appears and then
press talk/flash or speaker. The number stored in the speed dial (SPD1 - SPD0) is dialed.
Nov 30, 2007 | Uniden DCT648-3 Cordless Phone
Lands Phones Logo
52 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
