Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Blue screen when i turn on my tv, it turns on for about 10 seconds with the sreen blue,then it turns off.I try to turn it on again and it does the same thing.
    Novelist:
  • 192 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB.
Posted on Jul 04, 2007
SOURCE:
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
There is a lock on my screen and nothing works
Try holding the display button for 10 seconds, worked for mine, unless the vcr presents a different issue
Nov 10, 2008 | Insignia IS 20" TV040919 TV
Padlock, blue screen
Somehow in handling the remote control I pushed a button or combination of buttons and now have a blue screen with a lock symbol in red in the top left hand corner. I've tried turning the tv off, and unplugging it, as well as a combination of buttons on the remote, but it still is there.
What do I need to do to remove the lock?
Aug 02, 2008 | Insignia NS- 27" TV27 TV
Tv Screen Turns blue occassionally while running Toshiba DVD player
If the flashing is regardless of source, the CRT could be at fault. H to K short. ( heater to cathode)
Jul 23, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Osd menu locked
had exactly the same problem, hold down the menu under the screen for about 10 to 30 seconds, the osd warning disappears and the blue menu should come up.
Jul 11, 2008 | Philips Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
