Question about Cisco Coco Phone Retro Handset 3.5mm
The light isn't turning on and no one can hear me through the microphone
My wired headset isn't working, no one can hear me when I speak to them
Ricketfish srs wow - mic is not working
  • Press the PWR button on the wireless receiver to turn the unit on. The headset has a sleep/standby mode feature to preserve battery life. The unit goes into sleep mode if there's no input for 3 minutes.
  • Twist the tip of the microphone so the sound holes face your mouth.
  • Position the microphone several inches away from your mouth so it does not overload when you speak. Try to balance the microphone position and the volume setting for optimum voice level.
  • Press the ALL MUTE button (the Rocketfish logo) on the left side of the headset once to make sure that the All Mute function is not activated. The LED on the wireless receiver will light red when All Mute is activated.
  • Make sure that the volume on the wireless receiver is not turned down or muted. The LED on the wireless receiver will light orange when Mute is activated.
  • Rotate the CHAT VOLUME dial on the wireless receiver to control the chat volume.
  • Make sure the USB cable is connected to both the wireless transmitter and your device.
  • Make sure that all connections are correct and secure. Sometimes a cable may appear to be connected but it may not be pressed in all the way.
  • Make sure that the wireless receiver batteries are installed correctly. See Question 19.
  • Make sure that the wireless receiver batteries do not need replacing.
  • Make sure that the microphone isn't plugged into the Line In port (or vice versa).
  • Make sure the headphone jack is pushed all the way into the port.
  • If you're using an Xbox 360
    • Make sure the wireless receiver is connected to the Xbox 360 controller using the supplied chat cable. On the wireless receiver, press firmly, so no part of the silver jack is showing. This tight connection helps to make sure the cable does not fall out during gaming.
    • Try a different Xbox controller.
    • Try recording a message to a friend by selecting My Friends, Send a Message, then Add Voice. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
  • Try testing the microphone by connecting the headset to a smart phone and make a test call or record a memo. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
If these steps don't work, then I would advise seeking replacement.
Jan 21, 2013 | Rocketfish Srs Wow Wireless Gaming Headset...
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
Trying to use the headset provided by Dragon 11 naturally speaking software. The headset has two jacks, a mic and a headphone one which I have set up via RealTek, although I cannot get playback on the...
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
Jun 18, 2017 | Nuance Dragon NaturallySpeaking 11 Premium...
My USB headset (Wintech...China) won't work with GT5. It works perfectly in PS3 chat and in audio device settings (menu). In game i can hear people talk but they can't hear me. Chat indicator...
Hi, this may not be super helpful but the only thing I can suggest with this problem is to go to your game options and see if you can change any settings for your microphone or headset through there. If you are still unable to find a solution try to unplug and reset everything.
If you still are having the same issue I suggest contacting either the headset's manufacturer for technical support, or the Playstation technical support.
I hope this helps
May 17, 2011 | Video Game Consoles & Games
My motoriola H710 headset is paired, but no one can hear me
The microphone no longer works. Don’t know if you can change the Microphone of your headset through some authorized service personnel or not.
Jun 04, 2010 | Motorola Mobility H710 Bluetooth Headset
My headset is working except for be able to hear me speak
There are no mute buttons for your bluetooth headset, your microphone must be blown off, try contacting service personnel, you will get it fixed.
May 24, 2010 | Motorola Mobility H700 Wireless Headset
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
Crackly Headset
Mate, im having the same Problem i have no idea what to do!
When the Red light is on, it doesnt crackle, but when the Red light is on.. i cant use it as a Microphone.
But when i turn the red Light off.. there seems to be a crackly noise everytime i speak!!
I did manage to fix it for like a day.. i just pushed all the wires and it seemed to work. but hasnt for over a month now..
Aug 16, 2008 | Microsoft LifeChat Stereo Headset with...
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Cisco Coco Phone Retro Handset 3.5mm Logo
57 people viewed this question
Top Cisco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
