Puhz-rp125vha u9 fault code - Heating & Cooling
Daikin air conditioner flashing fault code u9
U9 System communication failed Fault with other indoor unit, ie no power, Faulty PCB
Aug 10, 2012 | Heating & Cooling
Code u9-80
This indicates a communication failure between the Main Control Unit and the operation control circuit board. Power the machine down and disconnect from hte power supply. Check all the connectors and wiring on the boards and also any loose wiring that may be grounding the machine. Power back up and if the fault persists a qualified copier engineer will be required.
Mar 10, 2010 | Sharp AR-M237 Copier
The air conditioner wasn't on and the control box was displaying a U9 error
u9 error code means there was a problem with voltage to the unit.Can be caused be either overage or a shortage. Have you had any power outages?
May 12, 2009 | Heating & Cooling
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Error code U9
hi im jules_09,are you sure its an error code?chek first all sensor on front door and other parts of the copier that has a sensor,
Nov 02, 2007 | Office Equipment & Supplies
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
