Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W Tantus 61" DLP occasionally will not turn on.
When I try to turn on the television, it will cycle 3 times and then all three lights on the front will illuminate. I have to unplug the set and try again. Usually, after I unplug the set 3-4 times and power it up, it will eventually start up. Any idea what causes this problem?
  • cigrs71 Feb 24, 2009
    same problem with my hln467w. it's been happening for years. I think I've finally hit the wall today. Have cycled through many times with no results.
    Most times i can hear the sound come on before the screen ligts but not this time. I read something about the ballast being out. has happend several times over the years even when new. usually comes on after a coulple cycles
    President:
  • 788 Answers
It sounds to me like you have an issue with the ballast not firing the lamp. It sound like you know to check the lamp, but there is no way to check the ballast, unless you replace it. The ballast is not that tricky to replace, but if you are not sure I would refer you to a technician to replace the part.
Posted on Apr 30, 2009
Inputs no longer getting signals
More common is storms wreck the cable box. But try unplugging power to everything for 1 minute. and retry.
May 04, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
Samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Feb 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No picture but sound once it goes off there is 3 blinking lights
Most likely for this symptom is the lamp. If you'd like you could sit behind the set and have someone turn it on, you should hear the color wheel spin up and then you should hear the ballast try to fire the lamp, it makes a small arcing sound. If the lamp doesn't light the process starts over again.
Jan 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
334 people viewed this question
Henry  Thomas
Henry Thomas
