I have ZIPSPIN ZPFS1-DVD FLASH TO DVD SLIM DRIVE COPIER IT WORKED FINE FOR ABOUT FIVE DISCS COPYING MY SD CARDS. THENIT SUDDENLY CAME UP WITH A FOREIGN LANGUAGE AND WOUL NOT COPY ANYMORE..
NONE OF THE THREE CONTROLS WILL GET IT OUT OF WHAT LOOKS LIKE A FOREIGN LANGUAGE, IT WILL COPY MY SD CARDS ANYMORE.
sandrew
  • 2961 Answers
SOURCE: Source Drive Not Ready
whatever programme you are using, ensure that if you have a second cd/dvd drive that this one is not set as the default burner, as there are normally options to choose. other than that the drive must be being used by another burning programme or a programme to read discs, so check that there are no other programmes running in the background that use the writer. Lastly, go to my computer, right click>properties>hardware tab>device manager and in the list dvd/cd drives, click'+' sign and on you drive, right click, select uninstal and reboot the pc, at which point the drive will be installed again automatically and hopefully, release the drive for whatever you want to burn.
Posted on Jun 04, 2007
sandrew
  • 2961 Answers
SOURCE: problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
sigma_shiva1
  • 188 Answers
SOURCE: Drive doesn't read DVD's, only CD's
ur dvd device lens is not working properly.......so that it only read cd-----
if u r drive is in warrenty....then replase it.....or go to any computer hardware shop may be they solve u r problem.......
best regards & best of luck..
Posted on Oct 27, 2007
  • 75 Answers
SOURCE: HP Lightscribe DVD 1040 dvd writer
try a firmware update
Posted on Jan 12, 2008
joebert
  • 29 Answers
SOURCE: source drive not ready on 1 - 7 cd/dvd copier
is it old? when a ROM have trouble in its lens that won't enable it to read any disc, then it will always tell you that drive is not ready.
Posted on Jan 19, 2008
Windows 7 wont recognize dvd when i put hallmark card studio in dvd player
Try cleaning the disc (clean cloth going from middle out, not in circles). On the computer that does read the disc, try copying the disc contents onto a flash drive and then try installing the program from the flash drive instead of the disc if the computer still refuses to read it after cleaning the disc.
Dec 26, 2014 | Hallmark Computers & Internet
Dont get anny thing on my ruku 2 ilike utube and netflex
Your device has no WiFi capability so you cannot get Netflix or YouTube,on the road or at home (you can forget about finding and connecting to an OPEN Wi-Fi network on the road !). As far as watching YouTube videos on your device, there is a workaround: download the videos to your computer, transfer them to an SD card or a flash drive (the flash drive option may not work because the USB port on your device may accept flash drives only for maps or firmware updates for the GPS) or burn them into a DVD and then put the SD card/flash drive/DVD disc into the appropriate slot on your device. But I hope you do not intend to watch videos while driving !
Oct 18, 2014 | Crown Ouku 7" Double 2 Din In Dash Car Cd...
Unlock micro sd password
A cd/dvd disc named PowerSuite has the utility on board to repartition and reformat static drives, cards, and mechanical hard drives. This software disc can Boot from the CD/DVD drive when starting up the computer because it has an operating system of its own capable of staring the computer without going to the main drive. Check it out!
Dec 24, 2013 | SanDisk 2GB microSD Memory Card
I have a SD M1502 DVD-ROM drive. it can read CD's just fine, but it can only read SOME DVDs. example: im watching an anime series, store bought, but when i get to Disc 4 the drive cant read it. the DVDs...
There are a couple of things to look at: First of all does your computer have software to read copy-
protected DVD's. Second if this anime set of DVD's is imported from Japan it might not be compatible with players from the US. If you look on the Internet you can find patches for your DVD player software to read foreign DVD's. Check out VLC and libdvdcss.
May 03, 2011 | Toshiba SD M1502 Internal DVD Drive
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Flash drive has a DVD ghost
It is "working as designed" for a 'U3' device.
A 'U3' device is _more_ than just an "ordinary" flash-drive.
You can install software onto a 'U3' device, i.e., a copy of Microsoft Office, and then you can take your data files _and_ your copy of the software _with_ you, and connect to any computer, and access your software and your files.
Jan 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Am trying to transfer DVD disc to Sandisk flash drive. What's the process? Thanks V
it sounds like you need to creat an .iso file from the dvd then drac and drop. is you flash drive 4 Gb
Jun 24, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cant copy DVD software to SD
write me at vince954@yahoo.com if this does not work. On the dvd there is also a zipped version of the map_sd directory, copy it to your pc and unzip it and then copy the contents to your sd card. as the file is so large, some dvd drives have issues reading it.
Aug 16, 2008 | Fine Digital FineDrive 400 GPS Receiver
Oct 01, 2007 | Samsung SD 616E (729507925578) Internal...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
