Question about Simo Nordic Cruiser 417 Stroller
Broken hood on nordic cruiser
Help!! I use my simo nordic cruiser all the time!! The latch on the hood broke off of the right side and now it no longer stays in one spot. It seems that the left latch cannot hold the weight of the hood with just itself. It is the lever that you can adjust when you want to put the hood forward or backward. The latch folds out for you to move the hood where you want it and then you can push it tight to make the hood stay in place. What should I do??? Thanks! Tara Petersen
  • 944 Answers
It appears that Simo have gone out of business, and their partner company Bertini is not supporting simo strollers, so I don't think you'll get much joy from them. Best I can think of is to take the stroller to any reasonable machine shop, and get them to make a replacement for the broken part from an appropriate material- it is probably the same or a mirror image of the one on the other side. This shouldn't cost too much, but ask first. A quick solution would be to fix an adlustable strap to the hood, going forwards and backwards from the front near the centre. This strap could then be attached to the handle and to the other end behind the hood. ( best way is a buckle stiched to the hood near the open edge, with one continuous strap running from a loop round the handle, through the buckle, then down to a piece of strong elastic attached to just below the base of the hood at the back. A bit of experimenting with the tension on the elastic should get this working quick enough). This may not be an ideal solution, but it may be easiest and cheapest. Hope this helps, if you need to find a machine shop near you then please give a general area and I can see if i can find you one :)
Posted on Jul 04, 2007
Cable broke how to open hood
If the handle broke you can grab the cord with a pair of pliers or vice grips and pull the cord. If it broke under the hood then you will have to see if you can see the latch under the hood then maybe with a screwdriver you might be able to pry the latch to the side and the hood should pop up. Let me know if it was the right information that I have provided.
May 13, 2015 | Cars & Trucks
My hood latch cable broke,how can I get under my hood
Gentlemen-
Remove the turn signal from the Drivers Side and push a long screwdriver into the spot until you trigger the latch, this is a tedious chore at best but sooner or later you will trip the latch and the hood will open, then pull the cross over cable and unlatch the hood. Please replace the opening cables, both of them and build an EMERGENCY HOOD CABLE and run it down until you can reach it from the outside, under the car. GOOD LUCK!!!!
Apr 27, 2014 | 1998 Volvo S70
PT Cruiser right side door won't open from inside
Only the inside latch...no big problem.. When connecting the latch be sure to apply the rod back in its position ..that's the sound you heard..good luck..
Jun 07, 2013 | 2006 Chrysler PT Cruiser
My pt cruiser inside release latch wont allow hood to close completely
The latch is probably just needing lubrication. In cold weather, try using a small amount of kerosene or diesel fuel (NOT NOT NOT gasoline) on the latch mechanism and drip some on the actuator cable too. Then before you close the hood, "work" the latch and cable several times to spread the lubrication and free up any parts that might have had corrosion on them.
Dec 02, 2017 | 2001 Chrysler PT Cruiser
My maytag microwaves fan stays on, i broke the bottom latch and glued it back on, still stays on' help?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("my maytag microwaves fan stays on, i broke the bottom latch and glued it back on, still stays on'"), as well as the answers to these questions:
Which fan is it, the internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Nov 24, 2009 | Maytag MMV4205 Microwave Oven
2001 chevrolet blazer hood latch won't release and open hood
if the cable is not broken then pull the release then take the side of your fist and pound on the hood starting towards the top drivers side and slowly move towards the latch try it a few times i have to do this every single time on my blazer
Mar 18, 2009 | 2001 Chevrolet Blazer
Hood latch problem on 2003 saturn vue
cable is a little worn,but what you can do is open the hood.on each side or the core support,its the long piece that is above the radiator are 2 black rubber hood stops,you can try bringing them up a little at a time(3/4-1 turn)equally as this will put more pressure on the hood and should pop right open.It may take mor ore less than the turns I said,also lube the hood latch with some good lube not WD-40 hope it works have a good day DB
Feb 12, 2009 | 2003 Saturn VUE
Nee Replacement Nut
Can you possibly take a picture of another nut on the carriage that matches the one you lost?  If so I can probably guide you better.
I don't know where you live but try taking the stroller into a hardware store that has a large selection of both Metric and English hardware.  Threads sizes  are all standardized and so are the nuts.  But there are just different styles to pick from.  You might be able to find the right thread size but he nut won't quite look like the original.  And the question is does it matter?  Look for a self locking nut also. One that has a "nylon" insert often called "Ny-loks".  Keeps the nut from coming off.  Get the right size you might want to replace all of them.
Nov 01, 2007 | Simo Nordic Cruiser 417 Stroller
Simo 417 Stroller - wobbly wheels
Sounds like the plastic liners that hold the wheel either on or together have worn out.  They make hundreds of different style wheels.  You can try going to any baby supply store that has replacement wheels that have the "same" mounting configuration and see if you can get new ones.  You might need to replace all the wheels and they may look different but at least you'll almost have a new stroller that doesn't wobble.
Oct 29, 2007 | Simo Nordic Cruiser 417 Stroller
Buckled back wheels on bebecar reverse buggy need to be repaired or replaced!!!
Graco
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
st_cust_prod_hd.gif trans.gif Contact Us
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Oct 07, 2007 | Graco DuoGlider 7444 Twin Seat Stroller
Simo Nordic Cruiser 417 Stroller Logo
199 people viewed this question
Top Simo Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Simo Baby Gear Expert? Answer questions, earn points and help others
