Question about GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher
Problem with door closing
Door does not stay closed (spring problem?) when not in use (not
latched)
THE PROBLEM SEEMS TO HAVE CLEARED ITSELF; DOOR NOW STAYS IN A CLOSED POSITION
Posted on Jan 22, 2009
Door will not close and stay closed. The latch appears to be malfunctioning.
A lot of times this is a broken spring or spring mount or the door latch heads.
If I had your brand and model number, I could offer more specific help.
Feel free to visit http://www.microwavecontrol.com and e-mail me form there.
Jul 27, 2016 | Microwave Ovens
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
Sharp microwave R-520K/R-520L door wont stay closed how can I repair it
There is a tension spring pulling the door latch assembly in a downward direction, keeping the door latch closed against the door switches and latch.
Spares required will be either a spring or a latch assembly both fitted inside the door. To get to them the plastic choke cover around the perrimitter of the inside of the door must be removed to reveal fixing screws.
eSpares Spare Parts Accessories for Electrical Appliances eSpares
Oct 31, 2017 | Microwave Ovens
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Door will not stay closed
Sounds like the latch is seized or the tension spring is broke.
You'll probably have to replace the latch.
Jul 27, 2013 | Cars & Trucks
I can't get the gas door to stay closed on my 2003 camry. the spring is not broke.
If the gas door is not latching then the retainer spring may be weak even if it isn't broken. You will need to replace this.
Jul 10, 2010 | 2003 Toyota Camry
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Door will not stay closed unless latched. spring
Adlust the level on the fridge so that the hinged side is slightly higheer than latch side. They reley on gravity to stay closed.
Dec 24, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
The latch that holds the door has snapped. time to take it apart. The spring may have come off or you could need a new unit.
Mar 25, 2008 | Sony PlayStation 2 (PS2) Console
GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher Logo
153 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
