The fire basket is a little too big for the fireplace. It would fit if I could get the sides off. Initially it looked like a couple of screws held the sides on but on closer inspection it is more complex than that. It looks to me that I will have to take the electric unit out and then access the sides. There are 6 screws on the bottom. The back four look to hold 2 simple brackets but I cannot id the use of the front 2 and need to know if I will damage anything by removing them.
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
I got a hold with Delta and they told me that model 4822 is obsolete and that they no longer sell the hardware. I need new brackets as well.
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
