Cursor fine. Example of problem: when I play Free Cell & click on a card it either doesn't move the card or it moves automatically. Also, in word, when I try to erase a line it doesn't do it right away. I have checked my computer & mouse & monitor working fine. HP is a 2001 model with Tower 7935. New Mother Board in 2004 & new hard drive in 2006. Monitor problems the last couple months - loose connection into monitor. Got to jiggle it for a while to get rid of the pastel colored screen, but then the screen ok. Installed updated Java and the problem has gotten worse.
you have so many posts with computer issues.!
if I had that id go back to pencil and paper. LOL
what mouse, ? a USB mouse or the MOUSE pad.?>
tell what Persario it is, lots of models made.
it has model number for sure use that everytime you post
and tell what OS it running there solutions all depend that.
and what mouse you own.
my guess some Lenovo USB mouse
A Persario name is a desktop and a lamptop
it has no fixed form,, that work
answer for say a desktop, no mouse pad laptop
I guess running windows XP the virus magnet and is infected
or the mouse is bad, try doing this.
1: try that bad mouse a good pc.
2: try a good PC mouse on the bad PC.
see?? hardware is eliminated from the cause.
or if all mice fail ,that is bad Software.
top reason bad mouse driver.
but if XP , the online drivers are gone now.
so tell
what PC this is
what OS this is
and answers can focus way better. ok?
the control panel has mouse icon click that and test the mouse.
it has a click speed test there, try that,?
in device manager is the mouse driver bad>?
It is possible that you accidentally hit the click-lock button, usually located below the little screen where you move the mouse by fingers. Try to hit that area again, and release the mouse cursor to roam the screen again.
Try cleaning the lazer on bottom with a q tip with some rubbing alcohol on it. Check to make sure the reciever for the mouse isn't too close to any wireless router,phone,or microwave. In the control panel there are mouse settings you can play with too to see if that makes a difference. Re-install any software for the mouse.
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Your mouse could be defective, but let's try a few things first.
Try to remove any wireless devices close to it (i.e. wireless router)or try to plug it in a new USB port.
Last thing try to use a very dark mousepad. The laser respond to reflection so any white on a mousepad combined with some sun light could result in a free for all mouse pointer.
Click Mouse.
When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
Figure 1: Pointer Speed
Click OK.
Acouple people have had this problem the touchpad is very sensitive I would recommend you press the small button above it to disable the mouse when you are typing for a long time . you then can press that button again and it will let you move the mouse again. Im new on here so if my solution helped you please give some good feedback on my answer thank you
