Question about Kenmore 45062 / 45069 Electric Kitchen Range
Exterior glass trim on Kenmore Electric Range 880-5981
How do you re-install the exterior glass trim on the door of the Kenmore Electric Range 880-5981. We took the exterior glass, the door handle and trim off to clean up a spill that went into the door in-between the exterior glass trim and the front of the interior glass of the oven door. Now we can't put them back
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Posted on Jan 22, 2009
White spots on exterior of microwave door glass
Exterior or interior? If they are on the exterior then something unassociated with the oven has caused them. If they are between sheets of glass then could be silacone fume residue or if it has a clear plastic filter on the inside of the glass, could be that. If they happen to use laminated glass, it could be the plastic middle but I doubt they would. Radiation leaking from microwave ovens is really a bit of a myth. Yes, if you have a damaged seal and there is a big enough gap, microwave radiation can leak out but unless you are hugging your oven, it's no real drama, according to current medical experts.
May 05, 2017 | Kenmore Kitchen Ranges
2004 ford expedition eddie bower
For the rear window, just need adjuts the both slightly...
Check the next procedure to Power Mirrors...
Diagnosis & Testing
The exterior mirror control switch receives power through circuit SBP12 (GN/RD) and ground through circuit GD143 (BK/VT). The exterior mirror control switch uses circuit CPM23 (GY) as the common circuit for both exterior mirror up/down and right/left movement.
  1. Possible Causes:
    Fuse 12 (7.5A) (SJB) An open in circuits CPM23 (GY), SBP12 (GN/RD) or GD143 (BK/VT A short to ground in circuit CPM23 (GY) A short to voltage in circuit CPM23 (GY) Exterior mirror control switch.
  2. Checking the voltage at the mirror switch:
    Key in OFF position. Disconnect: Exterior Mirror Control Switch C527. Key in ON position. Measure the voltage between ground and exterior mirror control switch C527-1, circuit SBP12 (GN/RD). Voltage should be greater than 10 volts.
  3. If voltage is greater than 10 volts, check that fuse 12 (7.5A) is OK. If OK, REPAIR circuit SBP12 (GN/RD) for an open.
Exterior Mirror Motor Synchronization
NOTE This procedure must be performed any time the power folding mirrors are manually folded in or out, or if the position of the mirror case has been moved without using the mirror control switch.
NOTE If the power folding mirrors are folded or unfolded continuously (6 to 10 cycles), the power lockout feature will disable the system for 2 minutes to prevent damage to the power fold motors. After 2 minutes have elapsed, normal operation will resume.
  1. Set the mirror control switch to the CENTER position.
  2. Use the mirror control switch (press rearward) to automatically cycle the power folding mirrors in and out 4 times.
  3. When an audible popping sound is heard, the power folding mirror motors are synchronized.
    NOTE It may be necessary to cycle the power folding mirrors in or out up to 4 times before they are synchronized.
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the precautions section.
    NOTE If equipped with power folding mirrors, they must be synchronized any time the mirrors have been folded or unfolded without using the mirror control switch. Refer to synchronization procedure.
  2. Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
    CAUTION Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
  3. Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
  4. Carefully pull the top edge of the glass away from the exterior mirror housing.
    0996b43f802029e0.jpg Fig. Mirror Glass removal shown
  5. If equipped, disconnect the heated mirror electrical connectors and remove the glass.
  6. Remove the 3 exterior mirror motor screws and exterior mirror motor.
  7. Disconnect the electrical connectors.
  8. To install, reverse the removal procedure.
Switch
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors. Navigator Trim Panel Removal
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
  10. Depress the locking tabs and remove the exterior mirror control switch.
  11. Remove the exterior mirror control switch.
If you dont want waiting more time for the Owners Manual, can check here this choice 2004-Ford-Expedition-Owners-Manual
Hope this help.
Apr 23, 2010 | 2004 Ford Expedition
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
Mar 24, 2010 | 2002 Ford Explorer
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Apr 12, 2009 | 1999 Ford Explorer
2006 ford focus driver side mirror (electric)
Not that hard on this model.Here is a pic of the mirror and the removal and installation proceedure.
http://i253.photobucket.com/albums/hh43/chuck943/N0025797.gif
  1. Remove the exterior mirror trim cover.
    1. Release the retaining clip.
    1. Disconnect the exterior mirror control switch electrical connector.
  1. Remove the exterior mirror bolt.
    • To install, tighten to 11 Nm (8 lb-ft).
  1. If equipped, remove the exterior mirror screw.
    • To install, tighten to 2 Nm (18 lb-in).
Mar 02, 2009 | 2001 Ford Focus
Side mirror of 2005 ford explorer
All vehicles
  1. NOTE: Left side exterior mirror shown, right side similar.
    Remove the interior door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel Removal and Installation
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the inside door handle bezel from the trim panel.
  1. Remove the window switch assembly.
  1. Disconnect the window switch and power door lock electrical connectors.
  1. Remove the upper trim panel screw at the window switch opening.
  1. Remove the lower trim panel screws.
  1. s2n~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, do not pull directly outward for this step.
  1. Disconnect the power mirror electrical connector.
  1. Remove the trim panel.
Vehicles with power, heated or approach lamp equipped exterior mirrors
All vehicles
  1. Remove the bolts.
  1. Remove the exterior rear view mirror (17682).
Feb 23, 2009 | 2003 Ford Explorer
Replacement of Mirror/Assembly, 2004 Ford E350 Super Duty
NOTE: Aero mirror shown, dual arm similar.
Manual mirrors
  1. Remove the mirror sail cover to gain access to the exterior mirror retaining nuts.
Power exterior mirrors
  1. If equipped, remove the front door speaker.
  1. Remove the front door watershield.
All exterior mirrors
  1. Remove the rubber plugs and dust shield.
  1. Disconnect the electrical connector(s).
    1. Disconnect the power exterior mirror electrical connector.
    1. If equipped, disconnect the heated exterior mirror connector.
  1. Remove the nuts and remove the exterior mirror.
Jan 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Kenmore 45062 / 45069 Electric Kitchen Range Logo
742 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
