Question about Cisco Computers & Internet
Adaptor plug in - Cisco Computers & Internet
  • Cisco Master
  • 2,072 Answers
What's the question?
Posted on Jan 11, 2013
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Sep 12, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Acer battery no charge/plugged in "battery is criticically low"
This is a tricky issue, it's either a problem related to the battery or the adaptor.
Try removing the battery and just plug in the adaptor and see if the computer will boot. If it does then there's a problem with the battery and you just need to replace it, if it doesn't then there's a few other things it could be.
The two most likely options is that the adaptor is bad, or the AC port on the computer has become loose. Most of the computers I've repaired that had these symptoms was that the AC port was bad if the battery wasn't. The best way to test this is to plug in the adaptor and just see if it wiggles around a lot, if it's loose then it might not be connecting to the board correctly and will need to be soldered bad on. If it's not loose then the adaptor might be bad, you can test another adaptor on your laptop or that adaptor on someone else's but be carefull, I can't stress this enough, if you're going to switch adaptors you have to make sure that the voltage IS EXACTLY THE SAME and has the same amps, if the voltage is off you can damage the computer, if the amps is off you can damage the adaptor.
If by some fluke it doesn't seem to be the battery, and you tested the adaptor and the AC port doesn't feel loose, then the charging circuit in the laptop might be shot, in which case you'll need a new motherboard.
I think that covers everything, sorry for the wall of text
Mar 01, 2010 | Acer (56.04200.H22) (5604200H22) 200-Watt...
Hard drive stopped working after plugging wrong adaptor.HELP PLS!
i think that the usb interfacing corrupted so you have to open the cage and take the hard out and connect it to new usb interfacing cage
Jan 03, 2010 | HP (EK423AA) 300 GB Hard Drive
Am trying to use the ACK-DC10 adaptor for my Powershot SD1100 IS so that I can work on my PC without draining the battery. Neither the first adaptor or the replacement one I ordered works. Why not? I get...
One must follow directions, and I hadn't. The plug does not go directly into the adaptor: the compartment lid must be closed and then a flap in the lid is raised to allow the plug to be properly fitted into the adaptor.
Aug 22, 2009 | Canon Cameras
I have a 2 Wire Switching adaptor that went bad.
  • generally it has no problem on that
  • what matter is the adapter voltage and ampere is compatible to the router
  • if you know to do it properly go ahead
Aug 01, 2009 | 2wire 1800HG Router (RG1800HG00)
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
Melting power adaptor
Is the power adaptor made for the country you are living in? It's possible the plug you are plugging it into has a higher current than the plug was certified for. Have you tried plugging the laptop in in another location (like, in a different building)? You may just need to replace the adaptor, how old is it?
May 01, 2008 | Gateway 7405GX Notebook
Computers & Internet Logo
22 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
