Question about Honeywell Programmable Thermostat Heater
Hooking up new thermostat to new furnace
I have a honeywell rth7500d thermostat. i have the G Y W R hooked up and the thermostat is not on. i have a blue wire also not hooked up. it is not hooked up in the furnace either. should this be my 24 volt supply and where do i hook it up in the furnace?
  • nwendtibc Jan 23, 2009
    what about "B" and "O"
    i hooked up the blue wire to c on the furnace and to b on the thermostat and the low volt fuse blew. the furnace instructions said to hook up c on furnace to b/c on thermostat for 24 volt. i am trying to power the thermostat so i don't have to change batteries and reprogram.
  • nwendtibc Jan 25, 2009
    What if a digital t-stat does not have a "c" terminal, but you want to keep it energized with 24 V? How is that done?
    Problem Solver:
  • 12 Answers
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Posted on Jan 22, 2009
  • 1 more comment
  • HVAC TECH 2 Jan 24, 2009
    The O terminal is for heat pump reversing valve being energized in the cool mode and the B terminal is for reversing valve being energized in heat mode. If rev. valve energized from O tereminal for cooling and the coil were to fail it would failsafe to heat, and just the oppisite if B terminal energized and rev. valve coil would be failsafe to cool. Rheem & Rudd are tippically the only manufacturer that energizes the reversing valve off of the B terminal in a residential application.
    Follow up on the wiring, when you hooked the blue wire to the C terminal at the furnace you should hook it up to the C terminal at the tstat. The previous message I explained the O & B terminal. If you have a gas furnace you should hook up to C terminal. Also, did you get into the installer setup to set your thermostat up for your system. This thermostat is compatible for multiple systems. If this does not answer all your questions check out honeywell.com and on the home page on the right side of page 3 gray boxes, enter tstat # and click on the box to view installation guide to navigate through the installer setup. Hope all this helps!!!
  • HVAC TECH 2 Jan 26, 2009
    Everything that I see on the internet the top left should be the C terminal which is common to operate tstat without batteries. If your tstat does not have a C terminal then that may be a design change that has not been upgrades on the internet. Check out this web address www.yourhome.honeywell.com Grey box labeled literature put tstat model # in and select above the model # highlight installation manual. If this does not help I will call honeywell on monday.
How to turn on my honeywell thermostat
Your thermostat should power on without a problem if it is battery operated, and even then, when you put batteries in it, it should still power up. Without knowing the exact model, the only other problem I can think of, the power to the thermostat is supplied by the furnace which is a common wire (usually blue) that is also hooked up to the C terminal on the thermostat. If there is a common wire hooked up, then you have to check if you have power to the furnace. If not, the problems could get more complicated. Hope this helps.
Jun 15, 2010 | Honeywell Programmable Thermostat Heater
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
I'm replacing an old thermostat with a new Honeywell RTH6300B programmable. I have propane heat and central AC. My old thermostat has a black, a red and a yellow leads with no ID on the old thermostat wall...
Open up the propane furnace and see what color wires are hooked to the gas valve or circuit board. If it has a circuit board, note which color is on the R terminal and W terminal, Connect the the thermostat the same way. Most likely the yellow wire powers your A/C so you can hook that one to the Y terminal.
Nov 27, 2009 | Honeywell Programmable Thermostat Heater
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
RTH2520B Honeywell Programable Thermostat wires
Hi soozankrayg!
Your problem should be pretty simple. (assuming that it is a typical 24volt system) you should hook up the black wire to the "RH" terminal and the white wire on the "w" terminal. Make sure that you turn off the power to the furnace at the breaker or the furnace itself before attempting this. The reason for this is that you can cause a short and either break the fuse at the furnace or burn up the circuit board. This can happen very quickly and is very common when a thermostat is removed.
Jan 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
I have a Honeywell T8000C1002 thermostat I got from my inlaws and it doesn't have the owners manual. I'm trying to hook it up to where an old rocker murcery honeywell was at and can't figure out how to...
Your red wire from the old R terminal goes to both the R and Rc terminal on the new stat. Other wires from old stat move to same terminal on new stat. You will not have any connections to the B or O terminal. Sounds like you probably already have it hooked up right though. This thermostat is what we call a power-stealing thermostat. It "steals" is power by running a trickle current to the transformer from the R terminal back through the W terminal. This meathod requires a standard resistive type thermal relay for the heating system. If you have an electronic type circuit board, many times they do not provide the proper type of connection for the thermostat to "steal" the necessary amount of power to run on. This is solved by installing a resistor from W to C in the furnace. If you have a standard electric furnace with thermal relays, then the problem is most likly the thermostat
Jun 22, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
3,431 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
