Question about Frigidaire GLGF376 Gas Kitchen Range
Frigidare range glgf376dsm display not working
Electric is fine because all the burners work with the ignitors. The display and oven light do not work.
  • 1 more comment
  • lounicosia Jan 22, 2009
    Thanks but..... Its not 220. It worked fine when it was first plugged in. I tried all the parts i.e. broiler, bake and set te clock. All of a sudden the display went out and the oveb light went on while the door was closed. I unplugged it and took a look but didnt take any covers off. When I plugged it back in the burners were the only thing that worked. Any other suggestions are welcome. Thank you.
  • lounicosia Jan 23, 2009
    Well I had the serviceman over because the problem started the same day it came. He said the control panel was bad and would be replaced as soon as it came in. He said he's seen this type of problem but usually not out of the box. I hope this is not a sign of future problems. Thanks.
  • Anonymous Mar 16, 2014
    frigidare range cpcs389ec3 oven light does not work
    Scholar:
  • 87 Answers
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Posted on Jan 22, 2009
  • Scott Wiuff
    Scott Wiuff Jan 22, 2009
    Duh, it's gas so I should have known it was 110! What's the model number? It should be on the lower end of the stove when you pull out the drawer.
Raange works fine, but oven will not light. checked valve on right side of burner. it is in the on position.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 25, 2010 | GE JSP26 Electric Kitchen Range
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
I have a Hotpoint RGB745 gas range everything works on the stove except for the oven. It now will not come on. the ignitor glows but will not light and if it does the oven will go out. the broiler works...
The ignitor gets weak and dim and does not allow for the safety device to open and let the gas flow. The igniter must pull at least 3.2 amps. I have a short video HERE
Dec 31, 2009 | Frigidare FED300E Electric Range
My gas stove won't turn light. The burner on top work fine, but the oven won't come on and there is no gas smell
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
adfda
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
The baking part of the oven does not work
joseph, you should hear a sparking when the ignitor is functioning. Very often, the ignitor for all burners is the same unit. You can try to light the burner when you first turn on the unit. If it lights, then find out what is going on. It is possible that the gap is damaged or dirty.
Dec 09, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire GLGF376 Gas Kitchen Range Logo
143 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
