Question about Philips Televison & Video
TV already digital?
Relatively current model; Phillips/Magnavox TV Mod #27MS3404. How do I know if it came equipped to handle digital signals?
    Sergeant:
    Champion:
  • 346 Answers
Check manual
Posted on Jan 22, 2009
I can't find my original Magnavox Model 20mf25iw remote. How can I change from DVD back to TV without it?
If you wish to select its input, you must have its original remote control. No universal remote control will go. Try get an original one. Contact the authorised service center for Magnavox.
Nov 04, 2013 | Magnavox New Original 27MS3404 Remote...
I have the Phillips Magnavox 20MT133S and my cable TV provider is switching to an all digital format. Will I require the use of their converter box for analog TVs? In otherwords, is this TV a digital TV?
Hello David,
Unfortunately this is not a digital TV, so you will need a digital cable box in order to watch the digital format cable channels on this set.
Hope this helps. If you have any further questions, please let me know.
Regards,
BElectric
Feb 26, 2011 | Philips Magnavox 20MT133S 20" TV
Magnavox model 27ms3404/17 tv,green light comes on,goes back off,but tv wont come on. saw the same problem listed for another model & was curious if it would be the same repair?
You have a corrupted eeprom! Location IC002. You must see the number of microprocessor IC001 and stereo IC1001 to decide which eeprom to purchase! And always when removing the eeprom to install an eight pin IC socket first. This way you may remove the eeprom in the event you purchase the wrong one or have replace at a another time. Rare but can happen!
Apr 04, 2010 | Philips Magnavox 27MS343S 27" TV
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
