Question about AOC L24H898-24 LCD TV
Model# L32W781 AOV tv just has a no signal sign floating, no picture
Hisense tv says no sign with blue screen
this simply means that the input you have selected is not being provided a picture signal , some common types of inputs would be labeled :
tv
cable
hdmi 1
hdmi 2
dvd
and so on
Jan 21, 2016 | Hisense Televison & Video
Does anyone know how to fix the following problem concerning an AOV tv model L32W716?
Problem Indicates Power Board Problem--They Are Available On eBay--Still Could Be A Problem In Availability In Afghanistan
Apr 14, 2015 | Televison & Video
LG lcd tv has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Jul 27, 2017 | LG 37LC5DC 37 in. LCD Television
Vizio TV with "No Signal" floating on screen
Tries take out the HDMI cable and replug it back in the HDMI socket.Unplug the Directv power plug and replug,press the off/on botton on again to reboot the signal.Should be every back to normal.
Sep 29, 2009 | Televison & Video
I'm house and pet sitting at a friends' house who have a large screen Vizio TV and DirecTV. Right now, the TV is set on HDMI, but there's a floating message on a black screen: ''No Signal!'' This...
You need to make sure that is has enough signal, if you have poor signal, you will get pixels(as oppesed to snowy picture on CRT televisions) make sure all plugs are plugged in correct, and try diff inputs from DirecTV to the Tv to ensure its not the HDMI input thats faulty. Good Luck.
Sep 26, 2009 | Vizio GV42L 42 in. LCD Television
5.1samsung surround sound
What model of Recevier do you own?
Are you just connecting Audio to the recevier? How are you connect the satelite?
Aug 25, 2008 | Samsung YP-K3 MP3 Player
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
AOC L24H898-24 LCD TV Logo
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
