Question about ON-Q Home Hms Heat/Cool Thermostat (36344501)
After work I found my home heating system turning on every 5 min
I finally turned the heating system off to avoid a fire. The temperature was maintaining 79 degrees when I shut it off. What should I do
  • 8,637 Answers
You may have to reset your thermostat and reprogram it. First I'd check to make sure the batteries are good. Had the same problem. Hopefully you have the booklet that came with it. Bud
Posted on Jan 22, 2009
Why does my home heating system comes on then off after five mins
Likely the cause is the plenum switch. The switch is temperature actuated, so the fan does not turn on until the temp rises, after shutdown the furnace temp "heat soaks" and the fan will come on and off, sometimes several times, and this is normal.....
Feb 27, 2012 | Heating & Cooling
I cannot find the place to put r134a in my 1998 Chevy malibu ls
Follow the Accumulator (round silver cylinder) low pressure hose to the fire wall. You will find the low pressure service port valve just before the fire wall.
Make sure you don't over charge the system, add small amount at a time and check the temperature every 3 min to 5 min by placing the A/C on max with the engine at 2000 RPM.
Once the temperature coming out of the vents are cold as ice with the engine at 2000 RPM. stop charging. So turn the recharge valve on for 20 seconds and then off then rev the engine to 2000 RPM for 3 min and check the temperature at the vent.
Once the temperature is ice cold, stop and don't over charge the system. Over charging the system will cause the A/C compressor to shut down and at worst break, causing a $500.00 repair cost.
Good luck and thank you for using fixya.
Sep 08, 2010 | 1998 Chevrolet Malibu
Replaced thermostat in 96 sun fire,good heat ran
You may of put thermostat in in wrong direction, The copper and spring side should be inside of motor.
Jan 15, 2010 | 1996 Pontiac Sunfire
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Honeywell - cm61ng- Keeps going on and off all night
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Hi! I have a problem with an oil heating system! When I turn it on, it heat for 5 mins then stops. I have changed out the circulation pump as I thought that this was the problem. The pipes in the boiler...
you may have many probs... 1 a poir boiler combustion. (not boiling the water) or just warming it up so it's not hot...that would mean your temperature sensor is broken or you have probs with the actual combustion process.. This could be an unsafe situation ..i would call a heating specialist right away.
Jul 12, 2008 | Heating & Cooling
After about 5 min my system turns itself off
hi the problem your having could be one of a couple of things the first to check is that all the speaker wires a fitted correctly and not come out of socket as a speaker wire shorting could give you the problem your having.
The second and most likely problem is going to be a problem with the amp part of the circuit board usually a blown resistor but in your case as the unit comes on for few minutes then the chances are its just a solder joint failing on the board this causing the unit to trip out as a safety measure to stop it setting on fire.
Check the sub woofer cable is fitted properly as this is the usuall problem with you make and model let me know when you have checked all of this ok
Feb 25, 2008 | Panasonic sa-ht800V Home Theater Audio...
Computers & Internet Logo
Top ON-Q Home Computers & Internet Experts
David Payne
David Payne
Are you an ON-Q Home Computer and Internet Expert? Answer questions, earn points and help others
