Question about Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking
A couple of weeks ago we started having problems with the various Function settings. When we turn the dial to select a Function setting, we can sometimes choose a setting, and sometimes not. There are times when the selector moves from one setting to the next, and other times when the selector jumps one or more settings.
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Farberware Turbo Oven T4850- can't understand temp dial
Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on I need all three knobs (temp, function & timer) for my Euro...
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Dec 06, 2008 | Oster 6071 Toaster Oven with Convection...
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Cuisinart Model TOB30BC Control Function
I have the same Cuisinart toaster with a different problem. In taking it apart to try and fix it, I may have gained insight in to fixing your problem. If your are willing to get under the hood of your toaster, you might try working with the electronic contacts that the function dial controls (it might void a warranty, but since you are out of warranty period no problem):
1. Unplug it from the wall
2. Remove the stainless steel case from around the toaster via the small screws around the toaster's bottom, sides, back and the black screws at the top just inside the door. This should allow you to see the electronics behind the dials.
3. Look at the function dial. by turning it you are turning a white plastic cam which presses down different combinations of metal electrical contacts to make the functions work. I suspect there is something wrong with the contacts that are pressed down to control the "BAKE" function. Turn the function dial to "BAKE". and Check the contacts that are pressed down by the cam.
4. Are the contacts free of crud or corrosion? If not, try cleaning them with a small brush or q-tip with CLR or some other rust remover or degreaser. After cleaning let them dry and plug in the toaster (once plugged in do not touch the electronics!) and try "BAKE" for a second. Turn it off and unplug it. If it works, reassemble. Otherwise try step 5.
5. Are all of the contacts pressed down by the cams completely in touching the metal on the plate like they are supposed to? If not, try bending them so they will touch when closed by the cam (but remain open when the cam is not pushing them). Are the contacts free of crud or corrosion? If not, try cleaning them with a small brush or q-tip with CLR or some other rust remover or degreaser. After cleaning let them dry and plug in the toaster (once plugged in do not touch the electronics!) and try "BAKE". If it works, unplug it and re-assemble.
6. If its still not working, email me (caseytronic@go.com). Maybe I can help. I am also willing to buy your toaster so I can fix mine.
Jan 09, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking Logo
59 people viewed this question
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raviteja
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
