Tried known working aerials. none work.
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
SOURCE: The DAB on my CR-515
Just had the same problem. Had a power cut in the area and it's wiped everything on my CR515. You need to reset it to the factory defaults.
On the actual stereo (not remote), switch it on, then hold the stop button followed by the on/off button. Clear will appear on the screen and it'll then turn itself off, When you turn it back on, it'll ask you to wait. Your DAB should be restored.
Bear in mind, this will reset all your presets and any other preferences you have set on your system. It should also, however, restore your DAB.
SOURCE: Bought Yamaha CRX-M170 Mini HiFi
No solution, but I have the same item showing the same problem
SOURCE: I have 6 preset DAB
You can download your manual for the radio at this link:
http://lowryelectronics.webeden.co.uk/#/gsdab0904/4536733630
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
