Question about Kenmore Refrigerators
Reverse door on kenmore refrigerator 461.62302
I need to change the door opening,reverse the hinges
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
SOURCE: Kenmore refrigerator door will not close completely
Both top and bottom doors will not close on mine
Posted on Feb 19, 2009
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
  • 63 Answers
SOURCE: is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
Posted on May 30, 2009
How do you reverse the door on a kenmore cold spot 106?
Take door off, reverse the handle and hinges to other side of door and reinstall.
Mar 04, 2016 | Kenmore Refrigerators
Can I reverse the door?
Janet,
Most of the time you can. If you look on top of you refrigerator, and you see some button covers on the side opposite from your hinge, you should be able to reverse the door. Second, open the doors and see if there are button covers on the face of the door frame opposite the hinge. If you have both, you should be able to change them. You usually will need a Phillips screwdriver, a flat blade screwdriver and usually a 3/8" socket or nut driver. Start with the freezer door and take the hinge loose on top and swing the door open and lift up on it and remove it. Next take the middle hinge loose so that the top of the refrigerator door is loose and you can then lift up on it and remove it. Take the grill off of the bottom front of your refrigerator and you will see where the bottom hinge is located. Remove the hinge and move it to the opposite side and then loosen the swivel pin and move it to the opposite hole and re-tighten. On the middle hinge you will need to turn it over from the direction it was originally mounted so that you can re-install it. You will also need to switch some pieces on the bottom of each door to the opposite sides so that each door will operate properly. Once all pieces are switched, including the handles, just re-assemble in reverse order that you took it apart. Hope this helps!
Jul 09, 2015 | Refrigerators
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I mant to reverse the opening swing of my refrigerator doors
You have to remove the doors, swap the hinges to the other side. Start by taking the top hinge off the freezer door (pop the plastic cover off the hinge to reveal the screws). If it has handles (some don't) you will need to swap them over as well. The screws are under plastic covers on the ends. There will be plastic plugs in the holes that will need to be removed and placed into the holes you took the screws out of. This is assuming your model has reversible doors. Most do, but some don't.
Jan 11, 2010 | Kenmore 70832 / 70834 Top Freezer...
We'd like to change the door from left opening to right opening on our refrigerator
Good day,
Before proceeding there are a lot of buttons and cover emblems that cover screw holes. Remove by prying off with a small screw driver as needed. As well, remove all food etc.
As well, keep track of all bushing and shims holding the door hinges in place.
1. With the top door closed, remove the top bracket. Open the door with both hands, open approx. 1 foot and lift off.
2. Remove the middle bracket, and remove bottom door as in step one.
3. Remove and reinstall handles on the opposite side of each door.
4. The bottom support bracket must be removed, and remounted on the opposite side, with the pin sticking up.
5. Reinstall in reverse order using bushing and shims as needed to assure correct alignment.
Dec 01, 2009 | Kenmore Refrigerators
How to adjust door hinges on fridge
on the door thats sagging on top of the of the door is a cap some have a screw holding it....if not use a screwdriver at the back of the cover and pop it up then you have small bolts some have 2 but most have 3 just loosen up but no need to remove then pull towards the hinge to see it move again move to the to where level you can place something in the gap between the door or have someone hold the door in place then reverse order to complete
Sep 06, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
83 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
