Question about Toshiba Satellite A205-S4607 Notebook PC
Internal microphone satellite a205
Stopped working... settings are all set so i do not understand. help?
Microphone not working
Do you have the proper microphone selected under skype audio settings? and do you have "stereo audio" selected and not "mono audio"?
Jan 08, 2014 | Toshiba Satellite A205-S5825 PC Notebook
I have a Pavilion dv6-3025dx and cannot get the sound to work for skype. Obviously there is a camera and that works fine but I could not get the audio to work - do I have to add a microphone. Can you help?
I understand that you are not able to us the microphone with Skype. As per the information provided in User Guide for the model it seems that the model has an Internal microphones .
Try configuring the internet microphone to use with Skype.
Open Skype - Tools - options- Audio settings- Set the input device as internal microphone and check the operation.
Aug 22, 2011 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
The internal microphone on my satellite a205-s5880 laptop quit working recently. I downloaded skype and it was working just fine, but then I deleted skype because I preferred gmail. I have tried to...
uninstall driver and restart your pc. After reboot your windows will automatically install driver. If not work on skype again, please verify mic with another application. After, if mic it`s ok, verify setting from skype
May 22, 2017 | Toshiba Satellite A205-S5880 Notebook
Hi, My laptop is: TOSHIBA SATELLITE A205-S5851 When using the Skype, I can hear perfectly but no one can hear me, I am not using an external microphone, can someone help?
This model Toshiba does not have a built-in microphone.
For people to hear you, you need a mocrophone.
You need to attach an external microphone to the Toshiba and configure Skype to use the external microphone.
Jun 27, 2011 | Toshiba Satellite A205-S5851 Notebook
The microphone on my toshiba satellite p500 has stopped working with skype
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
Feb 11, 2011 | Toshiba Satellite A205-S4607 Notebook PC
Does this type has been completed by microphone from the manufacturer?
Did you mean if Toshiba Satellite A205-S4617 integrated Microphone? If so, then the answer is no, the Laptop is not included or integrated with any microphone on it (not built on microphone).
you can read the detail and product spec here:
http://www4.dealtime.com/xPO-Toshiba-Satellite-A205-S4617
but you can still use microphone as an audio input, by purchasing external microphone.
Hope it help
regards
Apr 17, 2010 | Toshiba Satellite A205-S4617 Notebook
Internal microphone
Hi
check the Toshiba website for windows 7 drivers , download everything , bios update etc
click here for the link
Jan 08, 2010 | Toshiba (P000257700) Microphone
Touch pad not working
just restart machine in bios setup ckeck that touch pad option is set to enable. and also check some of the laptop has one switch on keypad or on the top of touchpad for on/off utility is set to on
Dec 27, 2009 | Toshiba Satellite A205-S5823 Notebook
Microphone poor sound quality
yes the microphone is poor quality in this model
Jul 08, 2009 | Toshiba Satellite A205-S4777 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4607 Notebook PC Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
