Question about Lincoln Welding Tools
HOW TO WIRE UP AMPTROL L3963-5 TO IDEALARCTIG 300/300 CODE7007C
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
Replace power cord
When a plug wire is replaced say on a stereo there is no hot or neutral it makes no difference which wire goes where there are instances where hot and neutral are a concern but not with a 2 wire plug that is not separated by color if you have 2 white or 2 black then there is no order just wire and go.When color is in question the wires will be colored I hope this helps.
Jan 20, 2014 | Dremel 300-N/55 300 Series Tool Kit
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
My K870 foot amptrol no longer lights off the welder. I jumped the "D" & "E" pin slots on the machine & it started, also can stick weld with that option which the tech support...
Hi:
Yes you can repair it yourself, the footcontrol has a micro switch that with time and use it wears out. Contact your welding sales rep or your nearest praxair store (www.praxairdirect.com) and request the micro switch, the sales rep will ask you for the code on the foot control, that one is on the plate on the footcontrol.
Good luck,
Jul 14, 2011 | Lincoln Electric Foot Amptrol K870
Will not weld or arc , I bought my ranger after hurricane ke ask a generator, and never elded with it. today for the first time I tried to weld with it and it will not arc
Make sure the WELD TERMINALS SWITCH is in correct position.: In the WELD TERMINALS
ON position, the output is electrically hot all the time.
In the REMOTELY CONTROLLED position, the output is
controlled by a wire feeder or amptrol device, and is electrically
off until a remote switch is depressed. If you don't have your manual, you can download one at http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=104081
Jul 18, 2010 | Lincoln Electric Ranger 305D K1727-2...
How resolveproblem by code 301 and p0 300
WELL P301 AND 300 IS MISS FIR CODES SO I WOULD DO TUNE UP OR PULL THE PLUGS AND LOOK AT THEM BUT 301 IS CYLINDER ONE MISS FIRE AND I DO NOT SEE WHAT YR THE CAR IS SO IF IT HAS SPARK PLUG WIRE YOU SHOULD REPLACE THEM PUT IF THE CAR HAS COIL OVER IT COULD BE THAT COIL ON NUMBER ONE BUT DO TUNE UP FIRST PLUG WIRE
Aug 14, 2009 | 1998 Toyota Corolla
EPSON LX-300
check the flex cable / cable wire attached on cartridge maybe thier a short on the cable.. also check the selection switch..
Jan 04, 2008 | Epson LX-300 Matrix Printer
Welding Tools Logo
55 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
