Question about Goodman Heating & Cooling
IS THIS A 1.5 TON OR 2 TON UNIT? aruf182416aa
ALSO, IS THIS AN R-22 UNIT?
4 Suggested Answers
  • 23 Answers
SOURCE: I have a 3 ton split system using a Rudd 3 ton
Both the other solutions are NOT proper Advice, i'm not saying this a put down, but if you want it to be right both of those answers are wrong
The truth is if you replace the condenser weather its a heat pump or strait cool, you need to match the equipment inside, ALWAYS use matched equipment otherwise your setting yourself up for failure. I've seen a ton of mechanics in my industry really mess people up by mis matching, Also you can install or service anything with refrigerant in it with out an EPA license. Trust me do it right, cause I hate having to tell people after its to late. Another thing these two are not telling you is that you need to match the metering device to the outdoor unit in order for it to work properly as well, and by the FLUSHING is risky on a coil, ok with line sets but risky with a coil.
Posted on Oct 01, 2010
heinzhvac
  • 229 Answers
SOURCE: I am removing a 3 ton condenser and replacing with
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Posted on Jun 21, 2011
  • 4736 Answers
SOURCE: Where can I find a
R22 has been banded by the EPA.. All units, no matter where they are in the USA, now use R134a refrigerant.
Posted on Jul 20, 2011
Can I buy a new inside unit for a MS24WN outside unit
EPA regulations: Freon 22 units are no longer available, Units that are compatible are available They come pre charged with nitrogen It must be dumped. If there is freon in the old system it should be pumped down into the condenser unit before the inside unit is removed, Close the high side king valve and run the unit until the low pressure reads near O Close the low pressure king valve. and turn unit off. 410A freon units are readily available. Most if not all 2 ton air handlers will work with any outside 2 ton unit though some building codes will not allow a mix. Their reason: if something fails who is to blame:
Dec 02, 2014 | Heating & Cooling
Comfortmaker
need more info on condenser itself the model number not coming up but the nomenclature u gave looks to be a 4 ton unit. why I say that is the 48 normally represents the btu's 12000 btu per ton. so 48 represents 48000 btu 4 ton. now this depends on your house 400 square feet per ton is a rule of thumb without doing a proper house inspection. how many windows type of windows all kind of stuff. so 4 ton is roughly good for a 1600 square foot house depending on all kinds of variables. if I can get a full model even if it shows ----00-- something like that I can give you a for sure answer. u may even get an r-22 unit which u can buy only as a dry unit companys still make them but can no longer ship them with r-22 in the they come charged with nitrogen which will save you a few grand on install because you don't have to change the indoor coil to a proper sized 410 a coil or the lineset. be aware of contractors who tell u to keep the indoor coil they will add a expansion valve and flush the lines with r-11 or rx-11 flush u wont get the efficiency or 100 percent working condition of a mix mash system.
Oct 20, 2013 | Heating & Cooling
Amana air conditioner unit, model ARUF182416AA keeps freezing over. filter is clean.
Freezing is caused by low freon pressure sounds like your unit needs to be charged.
Jul 26, 2012 | Amana Heating & Cooling
I have a goodman Model CKL 36-1K . It says Factory Charge oz R22 . Does that mean it uses R22 freon? The guy who sold it to me says it uses 410a and was only 2 or 3 years old. The serial # is 040637071 ....
Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
Jul 06, 2012 | Goodman CKL36AR36 Air Conditioner
Where can I find a new unit to replace my weather king 10aja3001 2 1/2 ton R-22 I want to stay with the R-22 . I live in Northeast Ohio
Jul 20, 2011 | Heating & Cooling
I am removing a 3 ton condenser and replacing with a 31/2 ton condenser . The evap coil is a 3 ton with an expansion valve with a 11/2 ton to a 3 ton rating. Will i have any problems. The 31/2 ton unit is...
Jun 21, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
We are replacing a 22 year old ruud UACC030/36AHW38 (this is listed as the equipment being removed from our home by one of the companies who has given us a quote). One of the companies is telling us that...
Hi, there are 12,000 btus per ton of cooling. You go by the numbers in the model number. I see you have a 030 which would be a 21/2 ton. I also see a /36a which could stand for a 3 ton, but its the 030 number you want. It is a 2.5 ton unit, no question! 2x12 is 24+6=30,000 btus, a 21/2 ton unit. Hope that cleared it up for you.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 12, 2010 | Ruud UBHC Air Conditioner
5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Jun 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
