Question about Xerox PHASER 6600 COLOR LASER PRINTER
How do I fix vertical blank lines in my documents
2 Suggested Answers
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Canon MP500 printing blank lines
I found an article with steps you can take to troubleshoot printer issues:
http://www.castleink.com/category/288/Fix-gaps-in-printout-horizontal-and-vertical-lines-Video.html
Still, have issues with your printer call me out at 1800-204-4427. I can solve you out via phone.
Aug 24, 2017 | Canon Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
Blank vertical line on pages
open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Xerox PHASER 6600 COLOR LASER PRINTER Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
