Question about Cobra 19 DX III 40-Channels Base CB Radio
GREAT TRANSMISSION HARDLY NO RECEPTION
Cobra 29 LTD Classic. Installed in 2007 Sterling, standing wave is below 3 has great transmission but will not recieve over a 1/2 mile , hear nothing but static.
  • Tom Zorn
    Tom Zorn May 11, 2010
    a SWR of around 3 will definitely harm your reception. the lower the SWR the better your reception And transmit. The antenna may need to move. if its magnet mount move it higher! or maybe to the trunk if it is higher. Good luck dropping the SWR's their are places ALL OVER the internet on how to do this.
    Besides that if its because of the radio make sure RF Gain is all the way up. and squelch is way down...
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Does the sterling have a fiberglass body? And where do you have the antenna mounted? And for decent performance, the SWR needs to be less than 1.5:1
  • 4 Answers
Need to take it in to have the SWR set on antena
Posted on Feb 19, 2009
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
When it's dry, I can't transmit, but when my antennas get wet,transmission doubles, WHY????
Hi John:
Try checking where the antenna is connected to the cable.
It may be corroded and you're not getting continuity unless it is wet.
Jan 08, 2016 | Cobra 29-LTD 29 LTD Classic CB Radio
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
I want to calibrate my cobra 29 NW Ltd. Classic
Calibrate For SWR (Standing Wave Ratio) http://www.cbtricks.com/radios/cobra/29ltd_bt/graphics/cobra_29ltd_bt_om.pdf
The CAL is only to calibrate meter for a swr check of you antenna system it does not calibrate radio.
Jan 11, 2011 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Mar 11, 2010 | Cobra 29 LTD CB Radio
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
Cobra 19 DX III 40-Channels Base CB Radio Logo
214 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
