Question about Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive
Wd10tmvv installation software - Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive
Can't install software
Check this procedure for Software Installation...
CAUTION:
Install EasyShare software before connecting the camera to your computer. If not, the software may not charge properly.
1. Close all software applications that are open on your computer (including the antivirus program).
2. Place the EasyShare software CD into the CD-ROM.
3. Install the software:
Windows: If you install window appears, select Run from the Start menu and type d:\setup.exe, where d is the drive letter that contains the CD.
Mac: Double-click the CD icon on the desktop and click the Install icon.
4. Follow the onscreen instructions to install the software.
NOTE: When the system tells you to take a few minutes to electronically register your camera and software. To register later, visit www.kodak.com / go / register.
5. When the system is prompted, restart the computer. If you turned off the antivirus software, reopen it. Refer to the antivirus software manual for details.
For more information, click the Help button in EasyShare software.
Hope thgis helps.
Jan 20, 2011 | Kodak Z8612 Digital Camera
MY COMPUTER WILL NOT RECOGNISE IT - I HAVE A WD MY PASSPORT SE 1TB AND MY OS IS WINDOWS VISTA HOME PREMIUM
If the following does not work (also if you tried rebooting your pc, checked all cables/wires, and tried a different port for the external drive) then you will most likely have to get the drive replaced. This is actually a quite common problem with the drive you bought.
Try this:
I'm assuming you're running Windows.
Sometimes if my external drive fails to mount. What I do to force it to mount is follow these steps:
  1. Click your 'Start Menu' and open up a command line window. Either find it in the Accessories folder or type cmd at the search.
  2. In the cmd window, type 'diskpart'. A new command window might pop up.
  3. In the new window, or the same one if a new one doesn't pop up, then type 'list volume'. It will list a number of volumes on the system in the following format:
    Volume ## Ltr Label FS Type Size Status Info.
  4. Find your hard drive in this list and note the volume number. I usually find the hard drive by comparing Sizes, but it should also show your hard drive's name under Label.
  5. Next type 'select volume x' where x is the volume number for your external hard drive volume. So for instance if your hd happened to be listed as Volume 3, you would type 'select volume 3' ------------- without the ' '
  6. Now, type 'assign letter=G' or whatever letter you want your volume to be.
Once you've done this, your volume should be mounted and you should be able to access your drive normally.
If this fails and all else fails, you most likely have a defective drive and should be able to swap it out under warranty. If a warranty swap isn't an option, I did find the following information that may help you to fix the drive so you can recover your data:
http://forum.hddguru.com/wd10tmvv-t16204-40.html
I hope this helps and I wish you the best of luck!
Have a great day!
Best Regards,
James
Dec 18, 2010 | Western Digital My Passport Essential SE...
How to install the network software please give the the software
If you have a network of computers, from time to time you will need to perform software upgrades and install new software onto the computers. Depending upon the size of your network, this can take anywhere from a few minutes to a few hours. Before installing software on a network, be sure to read the software licensing agreement. Most software programs only permit you to install the software on one computer per license.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions
  1. Step 1 Power on each computer within the network on which you would like to install the software.
  2. Step 2 Log on to each computer with the administrator username and password. If the network administrator has not established a username and password for the network, you will not be prompted for a username and password.
  3. Step 3 Check each computer to ensure that it meets the minimum system requirements for the software download (for example, the correct operating system, sufficient disk spacemag-glass_10x10.gif and correct processor).
  4. Step 4 Insert the software CD into the CD ROM drive of each computer on which you want to install the software. Enter the software license number or product key code. This will be located in your software package.
  5. Step 5 Run the software installation wizard. Some software programs may require configuration after it has been installed.
  6. Step 6 Remove the software CD from the computer after the installation is complete. Restart the computer.
Mar 12, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
My lexmart X5470 will not scan
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
You need to install the application software .just install the cd which come along with the scanner it contains the driver as well as the scanning software just install it .then you will be able to use the scanner button .
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components
Have a nice day and do not forget to rate please...!
Feb 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
Driver instalation for nokia 5130c-2
You need not install any seperate software for this phone. Just downoad and install the latest PC suite available from Nokia.com
http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download#
The PC suite software will automatically install the required softwares and drivers.
Jun 19, 2009 | Nokia 5130 Cellular Phone
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Error 2738 when attempting to install HP F4180 printer software
Hi Stargateforg,
Try the solution from HP.
Solution one: Restart the computer
  1. Turn off the product.
  2. Restart the computer.
  3. Turn on the product.
  4. Use the HP software CD or the downloaded software file to install the HP Software.
Solution two: Register VBSCRIPT.DLL
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
  8. Use the HP software CD or the downloaded software file to install the HP Software.
Solution three: Download and install the latest version of the software
  1. Click here to go to the software download page on the HP Web site.
  2. Type the product model name in the text box and click the gray arrow button.
  3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
  4. Under the Drivers section, click Full Feature Software and Drivers .
  5. Follow the on-screen instructions to download and install the HP software.
Solution four: Custom Install Use Custom Install to install the basic print drivers only.
  1. Use the HP software CD or the downloaded software file to start installing the HP Software.
  2. When prompted, click Custom Install .
  3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
  4. Follow the on-screen instructions to install the basic print drivers.
Dec 22, 2008 | HP Office Equipment & Supplies
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
Aug 19, 2008 | HP Office Equipment & Supplies
Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive Logo
94 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
