Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer does not run
Dryer does not do anything when you push the start button.checked the button and ohms out ok when you push it in.Door button is ok also timer does not sound like it is working also...
  • 67 Answers
The time my electric dryer acted like that, it turned out my door switch had gone bad.
Posted on Jan 22, 2009
Won't start and on/off LED is out. Getting power to the transformer and 'some' voltage out. Thermostat checked and all is OK.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Jan 14, 2016 | Dryers
Dryer quit won't start wife ran both washer/dryer same time put new breaker in still nothing?
Apr 18, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
I have an aeg lavatherm tn 95570 When I have started tumbledryer it will just go through the program without the motor running. The belt is ok and the only thing I can think of is, that the capasitor
Nov 20, 2014 | AEG Dryers
Ld505e power on board door switch ok no lights no start
Nov 09, 2014 | Dryers
I have as Kenmore 80 Series dryer. When we push start it does nothing
Sep 29, 2014 | Dryers
Kenmore 970 c85092 00 dryer
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Aug 19, 2014 | Kenmore Dryers
I have a Kenmore 80 Series dryer that just wouldn't start. The timer is getting power but motor doesn't seem to be trying to run. I wanted to take motor out to have it checked; I disconnected everything...
Jun 14, 2014 | Kenmore Dryers
Kenmore elite dryer wont start
May 27, 2014 | Kenmore Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Its plug in..when you push the button its never run
check the door pressure switch to see if its working. you can use a ohm meter for this test. you can also check by removing and inspecting the switch wires for lose fit. if the door pressure switch checks out ok, replace the start switch.
May 29, 2009 | Whirlpool Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
124 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
