Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
HD UPGRADE MITSUBISHI WS-55315
What is needed to upgrade a Mitsubishi 55" model WS-55315 tv to a high definition set? I understand that it is capable of going HD but do not know the process or the cost.
Thanks for your Help!!
Louis Kendall
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Posted on Feb 25, 2009
  • Mitsubishi Master
  • 8,617 Answers
Your set is already a high def set, you just need a Hgh def source such as cable HD or satelite HD then plug the source into the HD inputs on the rear of the set.
Posted on Jan 22, 2009
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi WS-55315 parental lock is on.and i have no original remote is there a fix
You are going to have to have a Mitsubishi remote to do it--with that contact Mitsubishi and ask for the 4 digit code to enter to do the hard reset of the set--puts everything back to factory original when set was new.
Mar 14, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a mitsubishi ws 55315 and i need to program my remote to the att uverse motorola cable box.
hi i have a couple of codes here for your mitsubishi tv just try them 0005 0151 0051 0004 0009 0254 0022 0141 0180. hope this would help! goodluck!
Sep 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
No color on mitsubishi 1080
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Oct 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi 55 in. WS-55315
Go into the menu and see if your closed captions are on and set to "TEXT". Setting the closed captions to "OFF" should solve your problem.
Jul 26, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
815 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
