Replace part 210007-1020
Replace selector switch
How do i get to the nettrual safety switch in a 1999 pontiac grand prix
Park/Neutral Position Switch Replacement
Removal Procedure
  1. Apply the parking brake.
  2. Block the wheels.
  3. Place the vehicle is the Neutral position.
  4. Remove the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  5. Click to Enlarge
  6. Remove the automatic transaxle range selector cable.
  7. Click to Enlarge
  8. Remove the wiring harness connectors.
  9. Remove the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  10. Click to Enlarge
  11. Remove the PNP switch mounting bolts.
  12. Remove the PNP switch.
Installation Procedure
Tool RequiredJ 41545 Park/Neutral Switch Alignment Tool
    Click to Enlarge
  1. Verify that the shift shaft in the Neutral position.
  2. ImportantDO NOT ROTATE A NEW PNP SWITCH. A new PNP switch is pinned in the Neutral position. If the bolt holes do not align with the mounting boss on the transaxle, verify that the shaft is in the Neutral position.
    Adjust the PNP switch if the new switch has been rotated and the pin is broken or if using an old PNP switch. Refer to Park/Neutral Position Switch Adjustment .
  3. Align the flats of the shift shaft to the flats in the PNP switch.
  4. Install the PNP switch to the mounting boss.
  5. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  6. Install the PNP switch mounting bolts.
  7. Tighten
    Tighten the PNP switch mounting bolts to 25 N·m (18 lb ft).
  8. Install the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  9. Click to Enlarge
  10. Install the wiring harness connectors.
  11. Click to Enlarge
  12. Install the automatic transaxle range selector cable.
  13. ImportantVerify that the engine starts only in the Park position or the Neutral position once the PNP switch is installed. Readjust the PNP switch and/or check the shifter and the automatic transaxle range selector lever if the engine starts in any other position. Refer to Park/Neutral Position Switch Adjustment and/or Automatic Transmission Range Selector Lever Cable Adjustment .
  14. Install the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  15. Remove the blocks from the wheels.
  16. Disengage the parking brake. Hope this helps, the page was read only so no pictures. Info is for 3.1L engine.
Jan 18, 2018 | Pontiac Cars & Trucks
The fan on my LG LHD45REL stopped working. Compresssor still works. How do I tell if the fan needs replacement or the control is faulty?
dear sir
if you can check by an electrical tester then first open control panel and check electric(main electric ) supply is reaching till the selector switch if its reaching supply the try to turn your selector switch on fan mode and check the connecting point of selector switch electric supply is now come on fan supply point ( where motor wire is connected that point ) if its working like this then its mean selector switch is ok and problem in fan motor , its need to replace .
hope answer the question
thank you
please vote!
Sep 30, 2010 | LG LHD45EL Dehumidifier
It seems as if the thermostat for the oven is not working.
GAS UNIT:ELECTONIC IGNITION
1ST MAKE SURE .(IF ELECTRONIC IGNITION, CHECK TO MAKE SURE THE PLUG FOR YOUR STOVE IS PLUGGED IN. IF IT IS PLUGGED IN AND YOU CAN'T GET IGNITION, THEN CHECK FOR TRIPPED BREAKER OR BAD PLUG IN OUTLET, OR GFCI RESET SWITCH IS NOT TRIPPED. IF ALL IS OK THEN MAKE SURE YOU ARE GETTING GAS TO THE UNIT. CHECK SELECTOR KNOB FOR PROPER OPERATION OR CRACKS TO MAKE SURE IT IS OPERATING PROPERLY. IF ALL IS OK THEN REPLACE SELECTOR SWITCH,THERMOSTAT IS CONNECTED TO THIS SWITCH.)
GAS UNIT:NON ELECTRONIC IGNITION
1ST MAKE SURE ALL PILOTS ARE LIT. MAKE SURE YOU HAVE GAS COMING TO THE UNIT. IF ALL IS OK, THEN DO THIS:
REPLACE OVEN SAFETY VALVE OR THERMOCOUPLE OR ADJUST THE FLAME HEIGHT AT THE OVEN PILOT. ALSO CHECK OVEN SELECTOR SWITCH FOR CRACKS OR PROPER OPERATON. CHECK THE SELECTOR SWITCH 1ST. IF ALL ARE OK THEN TURN OFF GAS TO THE UNIT FROM BEHIND THE STOVE AND REPLACE THE SELECTOR SWITCH, THE THERMOSTAT WIRE IS CONNECTED TO THIS SWITCH.TURN GAS BACK ON AFTER REPLACING THE NEW SWITCH AND CHECK FOR GAS LEAKS.
ELECTRIC UNIT:
CHECK THERMOSTAT KNOB FOR PROPER OPERATION. MAKE SURE IT IS NOT CRACKED. IF NOT CRACKED , LIFT OVEN TOP AND CHECK FOR LOOSE WIRING. IF ALL IS GOOD, CHECK FOR CONTINUITY ON UPPER AND LOWER ELEMENTS. CHECK BY REMOVING ELEMENTS, GET MULTIMETER, WITH ELEMENTS REMOVED, TURN METER TO VOLT/AMPS AND TOUCH RED TEST WIRE TO ONE END OF THE ELEMENT AND THE BLACK TEST WIRE TO THE OTHER END. IF IT READS OR MOVES AT ALL THE ELEMENT IS GOOD. TEST THE OTHER ELEMENT THE SAME WAY. IF ALL IS GOOD, RECONNECT ELEMENTS INSIDE THE OVEN. REPLACE THE ELEMENT. YOU CAN ALSO CHECK FOR VOLTAGE TO THE SELECTOR SWITCH WITH THE METER TO MAKE SURE IT IS GOOD BEFORE REPLACING THERMOSTAT.
Apr 13, 2010 | Kitchen Ranges
Dishwasher will not run. I have checked the circuit breaker and it seems fine. does the dishwasher have a reset button?
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Dec 25, 2009 | KitchenAid Dishwashers
Overfills with water
Load selector switch is either plugged or needs to be replaced. There is a tube connected to load selector switch and goes to washer tub. Disconnect from top and blow out, gets clogged with soap. If this doesnt work then replace load selector switch.
Sep 19, 2009 | Washing Machines
Washing machine over flowing during while filling. Would not switch to agitation.
mam the level controler and the timer or the electric valve of the water line of the machine will be having problem please check all these.machine will work fine.
Aug 18, 2009 | Washing Machines
Dual Surface Selector Switch
more common is the dual switch to be bad, but it is possible that the elemnt itself has burnt out, usually a 5 yr warr on the elemnts under glass
Nov 08, 2008 | GE Profile JP930 Electric Cooktop
Main selector switch
I suggest if you recently purchased the SELECTOR SWITCH , to get an exchange for another one , it could be a manufacture defect .
Apr 11, 2008 | Indesit W 123 Front Load Washer
Selector switch
the clicking of your selector is telling you that you have a fault but it does'nt tell you what type of fault . It could be anything from not being reset to a control board , or a motor to pump my advice to you would be to call an expert . goodluck
Mar 26, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
