Question about Mitsubishi WD-60738 TV
Blinking Picture On My Mitsubshi WD 60-738 - Mitsubishi WD-60738 TV
Mitsubishi wd-65638 dlp tv error codes sound no picture replaced the bulb I get a code of 6 blinking red and 1 blinking yellow
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help.
Blinking codes to Mitsubishi PTVs are given in detail.
Apr 10, 2013 | Mitsubishi WD-65638 65" DLP HDTV
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light wont turn on witch Mitsubshi kit should i get or any?
The V26 dm repair kit fom www.tvrepairworld.com should fix that issue and the Kit contains the step by step instructions on CD.
Jan 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking
Have you done a re-set on the TV at all?
Jul 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Getting a shadow where their are white areas
likely very dusty inside have a service shop do it, you can damage the optical unit if you do it wrong. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Mitsubishi WD-57732 Projection Television
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-60738 TV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
