Question about Kingston Kpex100 Digital Media Player
Kingston K-PEX 100 2GB not recognized by computer! HELP!
My computer will not recognize my K-PEX. Normally, when I plug the USB to the computer, the device says "Charging... Disconnect and reconnect for USB mode." When I do this the device briefly shuts off and turns back on with along with the previous statement. I'll just keep plugging and unplugging, and I'll still get the same result. If I'm lucky, the device will occasionally say "USB connected" but my computer still will not recognize it. The funny thing is that I was able to put music on before but now it won't.
Any ideas?
P.S. I've also tried the whole "install new hardware" tip and no go. Something about "see code 10". PLEASE, HELP ME!
  • 2 more comments
  • atisoft Jan 26, 2009
    Help Me please!
    I have a KPEX100/2GB and if I connect to PC, then say: "Charging ... Disconnect and Reconnect for USB mode". But never connected USB mode. Connect-Reconnect (more times), but allways connected "Charging mode". What I do?
  • Anonymous Feb 20, 2009
    its da same thing and i tried to reset but nothing.
  • jhay8cee Mar 24, 2009
    I have a KPEX100/2GB and if I connect to PC, then say: "Charging ...Disconnect and Reconnect for USB mode". But never connected USB mode.Connect-Reconnect (more times), but allways connected "Charging mode".
  • carjupu May 07, 2009
    My PC doesnt recognized my K-PEX100/1GB.
    What I can do?
  • 14 Answers
You can try other usb cable or if you have multi tester check all the line if all is ok.
i have check the lines with the help of this thread
http://www.fixya.com/support/t2808851-kingston_kpex_100_need_usb_cable
be sure that the black line is connected to ground,or you'll get charging only.
just solve one today by connecting theblack wire to grouind...
Posted on Feb 19, 2010
  • 32 Answers
Hi yea i had the same problem and i realised this was because i plugged it into a USB hub. if u do the same try plugging directly into the port on the system unit. If not u may not have the required drivers for this device.
Posted on Sep 01, 2009
    Problem Solver:
  • 6 Answers
There's a small hole where you can insert a needle size pin or any thing that will fit there to reset it. you can try this first.
Posted on Jan 26, 2009
I have a Kingston Data Traveler 8GB USB Flash Drive which I bought 4weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
The thumb drive might have some fault.
Plug it in other OS mainly windows XP and Linux.
If still same problem persists after tried in Linux, problem is with pen drive.
You can ask for a replacement from the dealer as it has guarantee for 5years.
Nov 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Window did not recognized my kingston usb (DT slim)
Usually all flash drive are plug and play devices if your computer is not recognizing it you should try plugging it into another USB port and even try plug in another computer to see if it would work.If your flash drive does not work this mean it is dead and the flash drives are not design to get the information off when it is dead.
Aug 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
try reinstalling the driver from the other solution or got to kinstons website and update the firmaware
try installing windoes xp service pack 3 if not allreadyinstalled
Jul 23, 2009 | Kingston Kpex100 Digital Media Player
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb not recognized?????????
The USB port in which your flash disk has been inserted muight be damaged. Try inserting it in another port.
Oct 22, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Non recognized Kingston pendrive 4 Gb
i bought a kingston 2 GB pen drive. computer does not recognize. device manager says drivers are not installed. but it works in safe mode. kindly help
Sep 08, 2008 | Electronics - Others
W98SE Driver for Kingston 1.0Gb DataTraveller Flash Drive
The people at your local computer shop are wrong but, Windows 98 should at least recognize the USB thumb-drive and ask for drivers.
I would remove all the USB Controllers from within Device Manager and restart; allow Windows upon restart to reload the USB Controllers; then plug in the drive and see if Windows at least recognizes and then install drivers.
It seems only the DTI/XX, KUSBDTE/XX, and DTII/XX support Windows 98.
Dec 04, 2007 | Microsoft Windows 98 for PC
Kingston Kpex100 Digital Media Player Logo
797 people viewed this question
Top Kingston Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kingston Audio Player and Recorder Expert? Answer questions, earn points and help others
