Question about Maxtor Computers & Internet
I Have an old Maxtor N256 Model 91080D5 IDE HDD 60 gig The Jumper Pin Configuration is not Marked , I want to run it master with slave 40 gig Seagate Ultra ATA
I have a Dell GX 270 it had a 40 gig hard drive: I have a few Hard drives I have this old 60 gig Maxtor works Fine. But The Jumper pins are not marked. I need to know What the pins are, to do what I want to do all I need to do is set the maxtor to master with slave on But the pins are not marked What is the pin Layout ?
2 Suggested Answers
cyberware
  • 196 Answers
SOURCE: Looking for the jumper pin settings to designate
on the right hand side put the jumper to make primary master
Posted on Sep 01, 2009
Maxtor n256 60 gb HDD jumper settings
Here take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 04, 2012 | Maxtor Computers & Internet
Take a look at this pdf:
then...
slave -----------
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
N256 40 gig hdd jumper settings - Model 5T040H4
It often depends what OS you are using. Linux i.e doesn't go well with cable select and I had to just play around with the jumpoer settings t get this drive to work. It is an old drive (~2000/2001), so it's slow and loud. I could not find any information on the Seagate nor Maxtor web sites. So try this;
The jumpers look like this:
If you bridge the most left pair, it is set to master.
If you bridge the second left pair, it is set to cable select.
No jumpers: set to slave.
"Cable select" only works if the IDE cable supports this setting. If you want to play around with it, look here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 27, 2009 | Computers & Internet
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
There is usually a diagram on the drive showing the jumper configuration.
Mar 16, 2009 | Maxtor Hard Drive
Computers & Internet Logo
67 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
