4-year old Dell 32
After the tv has been on for awhile, screen gets horizontal lines that go faster and faster and then vertical lines come on too. If you turn off the tv for about 20 minutes, it works okay. But, it starts up again after a little while. It used to happen after the tv was on for 2 hours...now it happens if tv is on for an hour. I live on Long Island. Can youhelp?
    Problem Solver:
  • 9 Answers
I can fix your tv for you. I am in Glen Cove, NY. email me at masterhu (at) yahoo (dot) com.
Posted on Jan 22, 2009
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
I have a Dell 32" LCD flat screen TV about 4 years old. After the tv is on for about an hour, it gets horizontal lines that go faster and faster and then vertical lines appear too. If you turn it off for...
please do not operate the same this is due to the sync separator problem which needs an mechanic or service center services . if you continue then the problem will cause a damage to the screen .
either the ic needs to be changed or some small condenser or a loose or dry solder connection.but remember not to open it your self and repair . pl send it to service center and let them handle the same.
Jan 22, 2009 | Dell W3201C 32 in. LCD Television
TV TURNS ON WITH NO PICTURE BUT YOU CAN HERE
you need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Dec 27, 2008 | Panasonic CT-32G11 32" TV
Black screen with colorful line going horizontally through the middle of the screen
Problem in the vertical circuitry.
If you have the know-how, check for "cold-solder" joints around vertical i.c.
Also, bad electrolytic caps.
Voltages ok?
Resistor values ok?
Replace I.C.
Don't tell me the yoke wires were off or gnawed thru by a roach!
Aug 07, 2008 | Toshiba 32A33 32" TV
No picture
Just increase the screen voltage slightly by turning the screen control on the LOT and if a horizontal line appears, check the vertical IC supply, and if everything is okay, change the vertical IC, it is not costly.
Jan 21, 2008 | Toshiba 32AF43 32" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
