Question about Panasonic ToughBook 52 Notebook
Hard drive will not boot, seen by bios but not seen by OS
Shut down computer and now OS cannot see hard drive, bois does see.
how do i get the HD to be seen by the OS again?
When screen loads it says windows cannot start because the file is missing or corrupt: \windows\system32\config\system
I checked with a ultimate boot load CD and it could not see the hard drive.
Help please
  • 8 more comments
  • tire_fryer Jan 22, 2009
    sorry, forgot to add
    Windows XP
    CF-52E
    computer is less than 3 months old
    currently on the road, this is a work laptop and I need it in the morning
    This will not go into safemode,
    the system cannot see the HD so windows never gets off the ground,
    I can push f8 and choose safemode but i get the same error, it does not make it to windows, it goes into the fault above before that
    I have not added anything new,
    I have tried to boot from the hdd in the bois but no luck
    I can get the boot cd to load but in the diagnostics it cannot see the drive, I am new to this ultimate boot cd as well (such a noobie) so any help with that would also be excellent
    Thanks
  • tire_fryer Jan 23, 2009
    I do not currently have a wincd
    both the hard drive and the cd drive are securly in. I did not add memory or anything.
    I shut the computer down just after startup at the login screen I am assuming that something got corrupted when the computer was shut down.
    I had a cd yesterday but do not have one today.
    I was going to down load one and then put the .iso on a usb flash drive and boot load from the usb hard drive in the bios
    Can I make a boot disk/usb boot disk from a different computer running the same software and use that to boot from.
    I do not have any cd's and will most likely be using a usb flash drive to do this.
    Please let me know if this is possible and point the noobie in the correct direction.
    Thanks
    Cannot get to command prompt,
    I will be at work before I get the CD and will have the techs there try
    I am in winnipeg manitoba canada, so probably pretty far
  • DEKR
    DEKR May 11, 2010
    can you go into safemode
    if so let me know
  • Jay
    Jay May 11, 2010
    Is it still under warranty? If it is take it back to the store cause the fix might void your warranty. Have the store technician do it for you.
    Genius:
  • Panasonic Master
  • 1,102 Answers
If you can get into safemode
click start then run
type msconfig
in general tab click normal startup mode load all drivers etc.
then click okay or apply
restart and then if a box appears click do not show again
hope this helps if not let me know
Posted on Jan 22, 2009
  • 5 more comments
  • DEKR
    DEKR Jan 22, 2009
    have you added anything like memory or upgraded os
    restart while in restart press F7 then choose to option boot from your hdd then enter
    see if you still get the error
    lf you do then put your ultimate boot cd in repeat above instructions except choose to boot with
    cd or cd/dvd
    let me know
  • DEKR
    DEKR Jan 22, 2009
    can you get back into bios
    in boot up options change in there to boot from cd or set cd as first boot option press F10
    to save and exit
    then restart with cd in drive
  • DEKR
    DEKR Jan 22, 2009
    were you able to get on system yet
    you have some major config problems
    I was hoping to fix them with safemode
    after restarting and constantly pressing F8
    are you able to click the lastknown good config
    do you have a wincd
    is your cd drive securely in
    and is hard drive in secure
    you did'nt add more memory
  • DEKR
    DEKR Jan 23, 2009
    I have wincd on my usb
    as long as you have your win#
    Honestly I would return it you said it's only 3 months old
  • DEKR
    DEKR Jan 23, 2009
    I am not sure your boot will recognize the usb
    let me do a few minutes of research
    your system is not that old you shouldnrt be having this prob
  • DEKR
    DEKR Jan 23, 2009
    can you get into command prompt by pressing F8 on restart if you can type c:\ chkdsk
    then press enter.
    I was talking to my partner and he said he would'nt you doing it via usb.
    Ifa there is anyway you can borrow CD from anyone that would be the best.
    You've caused yourself to lose windows files.
    If you were by me I would do it for you but your probably miles away.
  • DEKR
    DEKR Jan 23, 2009
    I'm in Brantford Ontario
    Your gonna need to reload windows so hopefully they have a cd
    if not and you have your wn registration # I can send you a cd
ACER ASPIRE 4710
This will occure for a couple of reasons.
1. Your hard drive has gone bad or the connectors have.
2. Your bois is set to boot from the network card, and not the hard drive.
1. boot to the bois, and look to see if it "sees" your hard drive. If not replace the hard drive. This will require you to install the OS and software.
2. Boot to the bois, check the boot order and remove or disable boot from LAN or PXE. If this is the problem you should now boot from the hard drive, if not you will probably still get the no OS found error indicating a bad hard drive (see 1 above).
Hope this helps
Jun 27, 2012 | Acer Aspire One PC Notebook
Dell dimension 3000 keyboard freezes up on bios options
I would try this, unplug the computer from the wall, reopen the case and you should see a small "watch" battery on the motherboard. This allows the computer to save the bois when there is no power. Pull the battery out, now before doing anything else; hold the power button in on the front of the computer for about 30 seconds. Let the computer set for a couple of hours (the bois at this point should be cleared, by I have seen were you have to leave the computer sit, so I added this). Put the battery back in the computer, turn it on and try to get into your bois setting. It accually should come up with an error to enter the bois because the date and time are way wrong.
Hope this works for you
Jun 27, 2012 | Dell Computers & Internet
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
Gigabyte k8m800-8237 wont boot with hard drive installed, hard drive beeps and computer shuts down. when I unplug the hard drive the computer boots with DVD drive. Hard drive is good, but used a 2nd one...
sound like you either have a dead SATA socket on the board, use another one, or at worst try a PATA hard drive, second thought is possibly go into the bios and make sure you have no previous hardware raid arrays left behind, sounds odd.. but i have seen it cause similar problems before.
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Hard Drive Error
This sounds like an issue with the BIOS rather than your hard drive if you are able to boot into Windows. Or do you mean that the PC boots to the windows install? What is the exact error and at what point in the boot process are you seeing it? The BIOS handles the the initial startup of your computer, before Windows is even accessed on the hard drive. If you can boot into windows, then try downloading the latest BIOS from Dell support and upgrade your bios. If you cannot boot into windows, and the PC is just going to the Install CD, then there may be a problem with the connection to the hard drive. If you have tried different hard drives in the same PC, then try swapping out the cable that connects the hard drive to the motherboard. If different cables do not solve the problem, then the problem may lie with the connector on the motherboard. If thats the case, then the entire motherboard will need to be replaced. Also try downloading the following CD to run diagnostics on your hard drive. This should provide further information as to what is wrong with your system: http://www.ultimatebootcd.com/
Sep 27, 2006 | Dell OptiPlex GX260 PC Desktop
Panasonic ToughBook 52 Notebook Logo
515 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
