Question about Home
Cannot control water temperature in Pfister Thermostatic Shower panel 016-700SP
  • 659 Answers
SOURCE: Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Posted on Mar 22, 2009
rahnzkie_18
  • 32 Answers
SOURCE: Fluctuating water temperature in new Price-Pfister Treviso shower
hi there! there is a technical problem in concern with that for sure...try checking the handle it might be loose already. things like that do happened all the time. thanks, kindly rate.
Posted on May 02, 2009
snap101
  • 117 Answers
SOURCE: The water coming out in the shower from a
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Posted on Jul 29, 2009
  • 21 Answers
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
Posted on Dec 03, 2009
  • 744 Answers
SOURCE: My GS thermostatic valve in my shower is slowly
Chances are that the thermostatic motor or element is failing and probably needs to be replaced. It will be necessary to turn off the water (hot and cold) to the shower valve, remove the handle, maybe the decorative plate (will depend on your model), then remove the valve assembly. If it's a cartridge, you willl need to remove the center clip and pulll the unit out with a pair of pliers. They do make a removal tool, but you may not need it. If the valve is a flange type, you will probably need to remove three to four screws and then genetly pry the valve out of its mounting. With this type of valve, there may be an "O" ring around the assembly that should be replaced so keep that in mind.
Some thermostatic valves can be repaired by replacing their individual components. Again, it will depend on your model.
Take the assembly to your local hardware or home improvement center along with as much information as you can, and have them match up the part(s).
Re-assemble the valve, then turn the water on before you re-install any handles or plates and check for leaks as well as proper operation. You can just slip the handle over the valve stem to test.
Posted on Dec 17, 2009
There is no hot water
Hi Marshall,
Do you mean that no hot water is reaching the shower, or do you mean that no hot water is coming out of the shower. The answer to this will determine where the problem is.
If no hot water is reaching your shower, then there is probably a problem with the boiler or the pipe is blocked. You can easily test this. You can turn on other faucets in the bathroom to check whether any hot water is reaching those.
If the problem isn't with the boiler and the shower is in fact receiving hot water, then the problem will be with the shower mixer valve, specifically the thermostatic cartridge. The cartridge controls water temperature. The inner workings of the cartridge move up and down to adjust the amount of hot and cold water entering the cartridge. If it has seized up, the moving part can get stuck in a certain position. It sounds like this could be the case with you and therefore replacing the cartridge should in theory fix the problem.
Hope this helps. Shower Thermostatic Cartridge Spares
Nov 14, 2015 | Home
Price-Pfister shower clogged after work elsewhere on water lines
remove cartridge blow out water lines be careful
Feb 09, 2013 | Price Pfister Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Home Logo
304 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
