Question about Honeywell Programmable Thermostat Heater
Inaccurate current room temperature reading
I have a Honeywell Chromotherm IV Plus thermostat. The current room temperature displayed is off - too low - by about 6 degrees. Is this adjustable?
  • Anonymous Feb 08, 2009
    Our programable t stat sometimes overshoots the design temp by 4-5 degrees before shuting down..how do I fix this
    Problem Solver:
  • 12 Answers
It is not adjustable, sounds like the LED is going bad. Tstat has battery back up for power outages. If you slide the fan switch from auto to on does the blower motor start? If not control problem with unit.
Posted on Jan 22, 2009
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My furnace has stopped working. the thermostat (Honeywell Chromotherm III) displays HOLD - AC. What does this mean? I replaced the batteries but nothing has changed.
Try to find a reset button or just change out the thermostat. I'm guessing you don't have the manual. Thats a pretty old model, I think you have to set the time and day before you can use the thermostat.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Cooling temperature will not below 70
controllers more than likely on a memory lockout... kill the power and take the batteries out of it... leave it for 60 seconds and try again... unfortunately you are probably going to have to replace the controller, sorry
Jun 16, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
450 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
