My washer has suddenly stopped before getting to the rinse cycle and i can't get it started again. it is full of water with my clothes in it.
  • fclapointern Jan 22, 2009
    It is a Kenmore special edition top loading washer. Model 20692.
  • Dan Harris
    Dan Harris May 11, 2010
    What type of washer is this? Is it a top loader or a front load washer? I can probably give you a solution if I know that, most likely though it sounds as if your pump is having a problem.
  • 59 Answers
Check your ground fault interupters (outlets with butons) under the sink and around the laundy room
then check the breakers in your breaker box
finaly call a sertified tecnition
Posted on Jan 22, 2009
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Clothes washer will not finish spin cycle.
maybe something in the drain pump take bottom panel remove pump by turning filter and remove debris dont forget to vacuum out water from drain hose or your gonna get really wet.
Feb 21, 2010 | Washing Machines
Whirlpool Estate Washer won't drain and won't work
Need a complete model number to help you. Access to the parts varies with different model numbers.
Aug 30, 2009 | Whirlpool Washing Machines
Clothes washer makes big noise after wash cycle
sounds as though you have a blockage in the pump/hose system stopping the water from getting out quick enough. check the filter out first.
Apr 05, 2009 | KitchenAid Washing Machines
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
