Question about Maytag Washing Machines
I have a maytag washer with model number A6125 serial number 082859NX that makes a clunking noise how do I fix it?
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
  • 30 Answers
SOURCE: maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Posted on Jun 02, 2009
SOURCE: can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
Posted on Mar 10, 2011
How do i find a user manual for a6125?
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct ;-0)
Good luck,
John C.
Apr 06, 2011 | Washing Machines
Washer makes a loud whineing noise when spinning or aggitate , oil on floor under washer, can you refil the transmision with oil
The transmission has a 10 year warranty, and you cannot refill without tearing it down. Check your owners manual for remaining warranty or call 1-800-253-1301 and they can tell you. They will need your complete model number and serial number.
Jan 13, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Ensignia washer is making a clunking noise like something is loose when it is in the rinse cycle.. also does not appear to be spinning as well as it should. What could be wrong with it
Mine had the same problem! Turned out to be the transmision going bad. My machine is only three years old. Transmision cost over $250 Not worth fixing. The inside of this machine is very poor quality. I am very disapointed. Maytag not the quality it once was. I WILL NEVER WASTE MY MONEY ON A MAYTAG PRODUCT AGAIN
May 24, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
It does not want to spin without making a lot of noise. What can i do it is only 4 yrs old
If it's a FAV6800A or FAV9800A run a Spin Only cycle with no clothes in
the wash basket. Do you hear noise like metal against metal? If so it could be Outer Tub Bearing noise. Please confirm you model number and first two digits of your Serial Number
Which is your machine? Rich
If it's one of these machine models we will continue
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Grinding during the wash cycle
I was told that it was the transmission - good luck with that....
Labor alone was $175 - I ended up trashing mine (3 1/2 years old) and buying a new one.
Just got off the phone with Maytag - by all means, try to get them to pay for stuff before you throw away the one that you have....Now that they know it's gone, I supposedly don't even have the right serial number...(it was hauled away 4 days ago by Lowe's)
Feb 02, 2009 | Maytag Performa PAV2200
Frigidare Washer Drum making noise when in spin
it is your bearings you need to replace both tubs and the basket but it will be cheaper and easier to buy a new machine to rebuild your washer it a pain in the **** because you need to take the whole machine apart. if you do decide to rebuild it make sure that you have someone else there to help the tub is bulky and has some weight to it
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag Neptune Washing Machine
can you reach inside the unit and grab tub and lift it up(as if perhaps the rear shaft has loosened causing more then a 1/4 inch of play in inner drum??? if that s the case sounds as if perhaps you have a bad rear bearing (over $700 in parts alone)
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
