Question about HP OfficeJet 4215 All-In-One InkJet Printer
Used hp printer
Need location of cartridge
    Novelist:
  • HP Expert
  • 297 Answers
See page 82-83 in the user manual.
Here is a link to the manual for your model:
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Posted on Jan 22, 2009
Does hp cartridge go on the left or right?
Hi Lisa here to help. To better assist you I would need to know which printer you have. If you open the print cartridge access door and look inside, you should see an indicator sticker that helps you too identify where the cartridge(s) go.
You can use the following link to identify your printer, then use the HP site to locate you user manual:
Finding Your HP Product Model Number
I hope this helps.
I work on behalf of HP.
Jun 16, 2015 | HP Office Equipment & Supplies
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
Cartridse error
If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
Instructions
Reinstall the ink cartridge
1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Wipe down the cartridge contacts
2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
3. Wipe from the top of the contact to the bottom. Do this for each contact.
4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Reset the Officejet printer
1. Turn on the HP printer.
2. Unplug the power cord from the back of the printer and wait one minute.
3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
My catrige has a error
Wipe Down the Cartridge Contacts
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move onto Section 3.
Reset the HP Deskjet and Photosmart Printers
Turn on the HP Deskjet or Photosmart printer, open the cover and remove both the black and color cartridge. Close the cover.
Reset the HP Officejet and HP PSC All-in-one Printers
Turn on the Officejet or PSC all-in-one printers.
Plug the power cord back into the printer. Press the On button and hold until printer turns on.
Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit at any office supply store such as Office Max.
Feb 28, 2011 | HP Officejet J5780 All-In-One InkJet...
How do I clean the printer head on ly HP J5780 all in one
Hello thanks for using Fixya
In
HP Officejet J5780 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Cotton swabs" & "Distilled water"
Now follow this procedure
  • Open the front door of the printer, located below the scanner lid, by swinging it down. The print cartridges will move to a position where they can be accessed
  • Unplug the printer to prevent the cartridge dock from moving away from the center of the printer. Press an ink cartridge down until you feel a "click" then pull it out of the dock.
  • Dip a cotton swab in distilled water and use it to clean any built-up ink from the metal contacts on the ink cartridge and from the area around the ink nozzle. Avoid touching the nozzle itself, which is located in the center of the bottom of the cartridge. Discard the cotton swab if it becomes dirty, and use another to continue cleaning. Keep cleaning until the ink cartridge is no longer dirty, then set the ink cartridge aside.
  • Remove the second ink cartridge and repeat the cleaning process. Set both cartridges aside until they are completely dry
  • Replace an ink cartridge by holding it slightly below the dock, then pushing it up and in until it snaps into place. Do the same with the second cartridge. The black cartridge is inserted into the right slot on the dock, while the color cartridge is inserted into the left slot.
  • Close the front door of the printer, plug the printer back in, and turn it on.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | HP Officejet J5780 All-In-One InkJet...
Why stil show empty after installation of refilled ink cartridge
As you were using a refilled ink cartridge, it needs to be reset. When you refill your cartridge, it will read as low or empty when you try to print with the cartridge.
There was a embedded serial number in the contact strip located on the back of the cartridge and your printer remembers that serial number and gives the message of low or out of ink. The internal memory is located in the printers firmware and is not in the software. It will remember the previous two cartridges ink level.
On this matter I need the exact model of your HP printer so I can assist you more further on this.
Let me know from you again here soon. Just leave a message and I will attend you ASAP.
Thank you for using fixya.
Jun 22, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
HP Photosmart 7760 wierd colours and white lines
In this case I would suggest you to clean the cartridges of the printer.
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
  5. When finished cleaning the ink cartridges and the cradle, print a test page.
Aug 03, 2009 | HP Office Equipment & Supplies
Where do i replace the the ink cartridge on a 3700dn printer
Although I can't find the specifics on your model, most HP allow access to the ink cartridges by lifting the front cover. The cartridges then move from their parked location. Note: the printer must be on when you do this. Perhaps you provided the wrong model number, here's a link to HP Support
Dec 07, 2008 | HP Printer Cartridges (Complete List): ,...
Print Stripes
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00226&lc=en&cc=us&dlc=en&product=304445&rule=42852&lang=en HP has indications that the lubricant on the printer carriage assembly tabs and the flex circuit contacts on the print cartridge can collect debris (fibers and dust), which may cause poor output. The lubricant is used to ensure that the interaction between the pen and the carriage assembly does not cause tears in the flex circuit. Refer to the following instructions to solve this issue. Cleaning the Inkjet cartridges can improve the quality of printing. If the printed page is missing lines or dots, or if it contains ink streaks, perform Procedure 1 in this section. If problems persist after performing Procedure 1, perform Procedure 2. NOTE: Use plain paper for these maintenance activities rather than more expensive specialty papers. Procedure 1: Cleaning the cartridge electrical contacts 1. Turn on the printer. 2. Open the top cover. The cartridges should move to the center of the printer. 3. Unplug the printer?s power cord from the power outlet. WARNING: Keep new and used cartridges out of the reach of children. 4. Remove the color cartridge. 5. Clean the electrical contacts (see Figure 1). Figure 1: Cleaning the cartridge electrical contacts A- Use a clean, soft, dry, lint-free cloth. B- Locate the copper-colored circuitry strip on the back of the cartridge. C- Wipe the coppers strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. CAUTION: Do not wipe the nozzle plate on the bottom of the cartridge. Wiping the nozzle plate can damage the cartridge (Figure 2). Figure 2: Do not wipe the nozzle plate 6. Remove the black cartridge. With a clean part of the cloth, repeat Step 5 with the black ink cartridge. Cleaning the electrical contacts inside the carriage assembly 1. Look for fibers or other contaminants on the electrical contacts inside the carriage assembly. The contacts in the printer can be damaged if too much pressure is applied during the wiping process. If necessary, the contacts may be cleaned by wiping them very gently with a dry, lint-free cloth (see Figure 3). Try to gently remove any visible debris within the carriage. WARNING: Make sure the printer power is turned off before cleaning inside of the printer. Figure 3: Cleaning the contacts inside the printer 2. Reinsert both cartridges. On models with cradle latches, close the cradle latch over the top of the cartridges. 3. Close the top cover. 4. Plug the power cord into the power outlet. 5. Print a test page. If the problem persists, go to Procedure 2. Procedure 2: Aligning and cleaning the cartridges Use the HP Deskjet Toolbox or Printer Assistant utility on the desktop (the utility name will depend on which HP Deskjet model is installed on the computer). NOTE: HP Deskjet Toolbox or Printer Assistant is for Windows users. HP Deskjet Toolbox: To align the cartridges from the HP Deskjet toolbox: 1. Open the HP Deskjet toolbox. The toolbox is located on your desktop in Microsoft ®) Windows XP, Me, 2000, 98, 95, and NT 4.0. In Windows 3.1x, the toolbox is located in the program group for the printer. 2. Select the Printer Services tab in the toolbox. 3. Select Cartridge Alignment and follow the steps on the screen. 4. After the alignment process is completed, perform a Cartridge Cleaning from the toolbox. 1. Double-click the HP Deskjet Toolbox shortcut (or icon) on the desktop. 2. Click the Printer Services tab. 3. Click Clean the Print Cartridges. Follow the instructions that appear on the screen HP Printer Assistant: To align the cartridges from the Printer Assistant: 1. Launch the Printer Assistant by clicking the Printer Assistant icon located on the desktop 2. Select tools and updates. 3. Go to printer maintenance. 4. Select calibrate printer. 5. Click calibrate and follow the onscreen instructions. Further instructions on calibrating the printer cartridges using the Printer Assistant can be found on document npd09616 - HP DJ 3320,3325 and 3420 series printers - how to calibrate the print cartridges After the alignment process is completed, perform a Cartridge Cleaning from Printer Assistant. 1. Select tools and updates. 2. Go to printer maintenance 3. Select clean cartridges. 4. Click clean and follow the onscreen instructions. If the problem persists, the cartridge should be replaced. If the cartridge still exhibits banding even after cleaning and priming actions in the HP Deskjet Toolbox are complete, the cartridge may need to be replaced. Verify the end for warranty date on the supply before returning it to the reseller. Typically, banding problems are most pronounced in images produced on plain paper in Normal mode. In many cases, simply changing to Best mode will alleviate the problem and produce satisfactory output. If switching modes does not result in acceptable performance, try using the cleaning steps described above. Internal test from the printer Running an internal test from the printer can perform a clean test. See document titled HP Deskjet Printers - How To Print Internal Tests for instructions on how to run internal tests. If the problem persists, replace the cartridge. Let me know if that helps. Good Luck, Tim
Mar 15, 2007 | HP DeskJet 5650 InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
